Old 03-10-2003, 05:43 PM
whiteracer whiteracer is offline
Send a message via AIM to whiteracer Send a message via Yahoo to whiteracer
Unhappy help :-( subs/amp
Will an Eclipse 3520 Amp power a JL 12W3 and a JL 12W1-8 sub? I don't know anything about the amp.
Name's David.
Old 03-11-2003, 03:20 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
why do you want to power two dissimilair subs with the same amp ?
Old 03-11-2003, 03:58 PM
why not? what will be affected?
Name's David.
Old 03-12-2003, 03:25 PM
Audio Guy
they are designed to take different power levels, play in different boxes, and probably vary quite a bit in their "stats" ......... you can try it out, but you might not be satisfied
Old 03-12-2003, 04:10 PM
ok scratch that, i already have a 12w0-4 and i just bought a 12w1-8. For the time being, can my sub handle both? Will the sound be the same or will it actually get worse?
Name's David.
Old 03-14-2003, 02:04 PM
Audio Guy
that's REALLY hard to say, since you are out of the mainstream of most people do. All I can say is try it, make a seperate box for each sub and see how they sound. You can try them individually and then together.
Old 03-15-2003, 11:41 PM
tazdev's Avatar
tazdev tazdev is offline
I'm still here
It is a bit of a different way to go, but ya won't know if it will work or not unless you try it.
Good luck and do tell us the result of the test
Stock Radio for installing Subs/Amp? robkule422 Car Audio 8 02-01-2011 07:29 PM
Need help with subs/amp setup RG501 Car Audio 7 05-15-2006 02:43 AM
need help asap!! subs - amps! Benjamin2005 Car Audio 2 11-22-2005 05:03 PM
Help With Subs/Amp bsazem22 Car Audio 5 07-28-2005 01:04 PM
Subs/amp help... 95HondaCivic Car Audio 18 05-06-2002 06:44 PM
