Old 05-12-2006, 03:13 PM
RG501 RG501 is offline
Send a message via AIM to RG501
Need help with subs/amp setup
i have a profile HA1000 2 channel amp and 2 kicker comp 10" subs. i tried hooking them up yesterday and failed at doing so. im not exactly sure what i did wrong. i went to my local car audio store and bought a wireing kit and a speaker level to RCA adapter. if you dont know what that is, its a connector type thing that allows you to plug a RCA cable into your speaker wire. i dont know if that made sense, but i hooked it up how the instructions told me to. so i assume thats right. i needed this cause i dont have a aftermarket CD player with RCA outputs. i plugged in the ground wire, the speaker wire, RCA cables to the line in inputs on the amp, and pretty much everything exept for the the remote turn-on wire. everything had good connections. so then i hooked up the power wire with the fuse in it. Put the on the positive battery knob then hooked the other end up to my amp. started up my car and the amp didnt turn on and nothing was comming from my subs. all the other speakers worked though. i dont know what i did wrong. do i have to hook up my remote turn-on wire for it to work? help is appriciated.
1996 v6 Pontiac Firebird
Old 05-12-2006, 03:45 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Need help with subs/amp setup
yes, the radio isnt turning on the amp.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 05-12-2006, 03:56 PM
tr10av tr10av is offline
Send a message via MSN to tr10av
Hook up the remote turn on wire to a wire that is +12V when the car is on. Usually people use a wire from their cig. lighter. Or, if you must (NOT RECOMMENDED) hook it up directly to the battery with a switch. If you do this and forget to turn off the switch you will drain your battery.
'87 Chrysler NewYorker
2 12" Ascendant Audio Assasins in Sealed Box
Hifonics TXi 6406 Bridged to 2 Channels
VR3 CD/MP3 Player
COMING SOON:
Component Set
Amp for components
Old 05-12-2006, 03:57 PM
do i just plug one end into the amp and the other into the radio fuse? what do i do?
Old 05-12-2006, 03:59 PM
pre98zetec's Avatar
hook the wire to the REM on the amp, then you could wire it to the switched power wire on the radio (i think this should shut the amp off?)
-Josh-
Old 05-12-2006, 09:39 PM
He doesn't have an aftermarket CD player so it might be kind of hard to find that wire on the factory harness as the wire colors aren't universal.
VR3 CD/MP3 Player
COMING SOON:
Component Set
Amp for components
Old 05-12-2006, 09:42 PM
pre98zetec's Avatar
true, you could try and wire it into a clock or something
-Josh-
Old 05-15-2006, 02:43 AM
NAVY IC's Avatar
NAVY IC NAVY IC is offline
you could use a test light, or a meter. what you wanna do is put your test leads on various wires in the radio harness and notice which leads have power when the radio is on, and cuts off whenever the radio is off. if none are switched off by the radio then try to find the ones that cuts off when the car is off. that's the wire you should use for your remote leads to your amp.
SELLING THE HONDA...
