Old 03-08-2003, 11:37 AM
Guido Guido is offline
Tamiya Rubbing Compound - a confession.
Yo guys,
I thought I used my nr. 1000 for a confession.
Although I've always been very sceptical about Tamiya Rubbing Compound, I picked up a tube later this afternoon in the local hobby shop (Broux for the Belgians ) and was too curious so I immediately gave it a go on a Fujimi's AMG SLK on which I'm currently working.
It takes off a bit of the paint surface but the result is just stunning! Paint is a self made metallic light blue and I sanded it down because of some light orange peel. Well, there are still some minor scratches, but I guess next time I'm not going to sand but use the compound immediately. Finished off with Tamiya Wax! :licker:
I hope to get it finished this week, so I can take some pics with my friend's digicam. Well this forum has learned this old fox a lesson! Thanks guys
Guido.
ps. When I'm at 2000 I'll confess using primer
Old 03-08-2003, 11:41 AM
AzNySj AzNySj is offline
Send a message via AIM to AzNySj
I dont think their should be scratches, the compound takes off the scratches right? I read in the FAQ that you should sand a little if you have some orange peel, than use the compound. Am i wrong?
Old 03-08-2003, 11:44 AM
No you're not wrong, It does take off the vast majority of the scratches, but for a perfectionist nutter like me, I can still see some, but I'm afraid to take it any further, so... From a distance (30cm) it looks very good, only when I put my nose on it, I can see them
Old 03-08-2003, 11:45 AM
oh... Maybe you should use a higher grit sandpaper?
Old 03-08-2003, 11:47 AM
freakray freakray is offline
AF Modelrater
Don't put your nose to it then
AF User Guidelines
I use 8000 to finish... so again, it's just me...
Old 03-08-2003, 11:48 AM
lol never mind than, hmm maybe I shouldn't sand my integra DC-5 and just use comound by itself. Do you have any pictures?
Old 03-08-2003, 11:56 AM
Like I said, unfortunately not. The guys around here know I don't have a digicam, so when it's finished I take to my friend and take some pictures there with his. So be a bit patient and you see them turning up here
Old 03-08-2003, 04:03 PM
tonioseven's Avatar
Just know that when he does show us pictures, it will be worth the wait!
Old 03-08-2003, 04:40 PM
primera man's Avatar
"P-Man"
Can i be the first to say We told you so:finger: :finger:
View All My Models Here.
Old 03-08-2003, 05:09 PM
bends's Avatar
bends bends is offline
I just tried compound on my first model and I end up with swirly scratches. Very tiny but you can probably see it clearly from even a foot away against the right light. What am I doing wrong?
I sanded it before compound with 1500 paper (highest I have) is this the cause? Should I go higher?
-Chuck
Old 03-09-2003, 02:39 AM
"P-Man"
-Chuck
Did you have to sand?
If there was no orange peel in the paint it would only have need a rubbing.
You really needed to go higher with the paper(2000+)
Old 03-09-2003, 07:14 AM
Sure you can
Old 03-09-2003, 09:04 AM
bends's Avatar
Yeah I kinda did Pman, I can't believe how much of a literal dust magnet things are- something I found out when I started spraying. Dust lands on my car every 5 seconds no matter how much I blow and brush off first. Maybe next time I'll just sand off the tiny bits of offending specks instead of the whole car body. As for my current project, I'll re-spray and sand with higher grit papers thanks.
-Chuck
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
