Old 03-06-2003, 08:18 PM
grncivicdhr's Avatar
grncivicdhr grncivicdhr is offline
AF Premium User
Send a message via AIM to grncivicdhr
Question how about an h22a? what will that do to my civics handling?
ok, heres an idea, i didn't send the $$ for the new engine yet (d16y8 / i do that tomorrow). its 1300 with a warrenty and shippin. i only wanted a small shot of nitrous so i don't get my ass kicked by any geo that rolls by. my main consern with the civic is handling like i had said (b/c of autocross). i was thinkin of saving another 1200 to get an h22a, but i was thinkin that if i put that motor in my car my civics record at solo 2 would go to sh*t since i'd over steer like crazy cuz the weight. what do you guys think of the h22a idea, how bad would my handling be and would a stronger/stiffer front spings fix the problem?
Old 03-07-2003, 01:53 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
The oversteer in an H22 is not that bad at all I rode in a civic with an H22 and it was not bad at all but if you are going to be doing Auto-X then stay with the Single Cam.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 03-07-2003, 02:02 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Well since your talking about understeer,not oversteer.And it is noticable,but not unmanageable in a civic.But when talking about auto X,when you swap it bumps you up into a class that is going to eat you alive.Even if you swap a B series in you still get bumped up.If your talking about your local events,then you can probably swing it,but still the H isn't a good choice for auto X.Honestly a stock CX with good suspension and a good driver will smoke a H22 civic's ass in autoX,so stick with your D.
Old 03-07-2003, 02:13 PM
You can get a good amount of power out of a D series anyways my z6 pulls pretty damn good. I say keep it all motor and build it up a little bit.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
S/S Brake Lines
Blitz LM Intake
Soon to come:
Blitz Down pipe
HKS FMIC
Old 03-07-2003, 02:33 PM
Yea,and sink all that money you have saved into a suspension and another tranny,with a LSD.You can devastate on the course.
Old 03-07-2003, 02:39 PM
You got it infact I am going to be ordering LSD for my Single Cam this paycheck. I am also getting a 6-puck and a Chromoly flywheel. Then I am going to be working on getting the head done over but I am putting a y8 head on those are much better for all motor Single Cams.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
S/S Brake Lines
Blitz LM Intake
Soon to come:
Blitz Down pipe
HKS FMIC
Old 03-07-2003, 03:30 PM
AF Premium User
thanks for all the imput, i bought the new d16y8 today, and for power bryond bolt ons, i'm going to fucus on head work.
Can my H22a type-r v-tech handle a turbo????? playboiicivic08 JDM Motor & Parts info/chat 13 01-22-2009 05:08 PM
How about a bad TPS sensor that causes braking problems? splouie Cougar 0 06-07-2004 03:08 PM
So how about that K seiries.. NerveAgent '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 04-24-2004 02:39 AM
what will this civic run!!!!!!!!! crazyH '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 11-10-2003 11:30 PM
