Old 03-02-2003, 08:07 PM
bluebb6's Avatar
bluebb6 bluebb6 is offline
This paint sequence?
I want to use automotive paint on my model. I was thinking about this procedure since I could only find clear automotive plastic primer:
1) Tamiya primer (probably white)
2) Clear automotive primer
3) Automotive paint
Would this be ok? Would this lead to too thick of paint in the end? The purpose of the Tamiya primer is to get the same final color on all the parts once I'm done.
Does anybody know if clear automotive primer can be sanded?
Thanks.
Old 03-02-2003, 10:44 PM
ales's Avatar
ales ales is offline
Forza Schumacher
I don't think you need the clear primer at all. Just make sure Tamiya primer covers everything nicely and evenly and is thick enough, and then make the first several coats of paint mist thin.
Old 03-03-2003, 12:02 AM
bluebb6's Avatar
Really? My impression from my search on the forum is that Tamiya primer is either not strong/protective enough or incompatible with automotive paint? Is that not true?
Old 03-03-2003, 12:05 AM
primera man's Avatar
"P-Man"
I think you need to stick to one brand for the primming and painting
View All My Models Here.
Old 03-03-2003, 06:40 AM
hirofkd's Avatar
hirofkd hirofkd is offline
I'm a little doubtful, but if the brand of the auto paint doesn't have white primer, I guess your procedure is alright. Check their catalogue, and see if they have white primer.
Hiroaki Fukuda
Old 03-03-2003, 11:03 AM
jimbob's Avatar
jimbob jimbob is offline
I agree with ales - I think that the clear primer in this case is not needed.
What u could do is go to your local paint supplier and buy a can of automotive Plastic Primer - This would solve any doubts queries you have.
I f do use Tamiya primer - dont apply it too thick just make sure u cover the model with a nice thin coat - give it a little flat off and the next step is to apply a mist coat over the primer (a dust coat hardley any paint) - if thats ok carry on as normal.
Also u will probably find u will need to clear laquer any atomotive paint as it will dry flat in colour.
JIM
Current Project : Yamaha M1
www.autoperfectionworld.co.uk
Old 03-03-2003, 11:06 AM
jimbob's Avatar
Oh forgot to say - you could always just use the clear primer - a thin coat
and then build up your final colour
What colour is the model?
What colour is your paint?
That will work - for a model you shouldn't have problems with ur final colour
JIM
prpoer painting sequence HELP! bobbyn Cars in General 1 06-03-2006 08:09 PM
Any one know this paint code to this car???? lambomambo Murciélago (Murcielago) 2 10-18-2004 09:19 AM
Highly reccomend this paint geofroley Car Modeling 17 06-01-2004 07:05 AM
What in the world is this paint problem? canjoman Exterior | bodykits | Lighting 4 06-27-2003 08:57 PM
Need help, anyone know whut color this paint job is? ShOrtyOC714 Car Modeling 14 03-27-2003 11:22 AM
