Old 03-02-2003, 05:07 PM
kris's Avatar
kris kris is offline
Off playing with fire.
code 6
Coolant temp sensor.
What causes this to go bad. And which one is it? Is it the single pin sensor, or the plug sensor, underneath the dizzy?
Old 03-03-2003, 04:45 AM
BlueCivic83's Avatar
BlueCivic83 BlueCivic83 is offline
Send a message via AIM to BlueCivic83 Send a message via Yahoo to BlueCivic83
i got the same error and i just bought the car. something i find odd the radiator fan goes on as soon as i turn the key on the on possition. If you find solution to this error please reply or email me [email protected]
Old 03-03-2003, 09:37 AM
dfarres's Avatar
dfarres dfarres is offline
Send a message via Yahoo to dfarres
i'm guessing its the single pin coolant temp sensor under the dizzy. If not there's always the 2 other thermo switches u can change..
1993 Civic Coupe EX
1997 Chevy Suburban LT
“It's all fun and games - Until someone loses an eye"
Old 03-03-2003, 01:54 PM
turbcivic's Avatar
turbcivic turbcivic is offline
Hondas are noturios for their TW sensor going bad, along with with their dizzy. Easy fix, no problem.
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 03-05-2003, 02:27 PM
kris's Avatar
Not really easy.
I have replaced both sensors, and still a cel.
I am thinking my brittle wires are the problem.
Old 03-05-2003, 02:47 PM
were are theur located ? and what is the dizzy ?
Old 03-05-2003, 03:51 PM
dfarres's Avatar
Originally posted by kris
Not really easy.
did u replace the 3rd sensor???? there's another one on the back of the block.
1993 Civic Coupe EX
Old 03-05-2003, 05:12 PM
plkelley's Avatar
plkelley plkelley is offline
Send a message via AIM to plkelley
It's also known as the TW Sensor....
Old 03-06-2003, 02:12 PM
turbcivic's Avatar
dizzy=distubator
Old 03-06-2003, 03:36 PM
dgonzals's Avatar
dgonzals dgonzals is offline
Send a message via AIM to dgonzals Send a message via Yahoo to dgonzals
Here is my input....
The last couple of days I been having the same problem....getting a code 6 on my 91 crx si.....This is what I have learned from this code....The sensor on the back of the block turns on the fan and also is not connected to the ecu....so you dont need to replace that the get that code to go away.....Check the ohms in the wires that are going to the coolant temp sensor....you are suppose to get like 5 volts....if you are getting no reaction then you know what the problem is....Once you do change the coolant temp sensor either take the hazard fuse off for 10 second or the battery for 30 seconds to reboot the ecu......one more thing to check....you could have a bad ecu....so get a spare one and change it.....see if that helps.......then start the ignition....it should be fixed.....that is all that i can think of right now....if you need more input....holla at me....peace...
Blaaaaaaaaaaaah!!!!
1993 Acura integra Stereo Code Omega-Factor Interior | Audio | Security 1 03-25-2009 07:08 PM
'98 Blazer - Codes, codes, codes! MAF & O2 LAN2UNOW Problem Diagnosis 3 03-02-2008 08:56 PM
codes,codes,codes vdubdad Beetle - New/New Beetle Convertible 0 10-22-2007 08:33 PM
Codes, codes, codes.... alkemist Riviera 7 06-19-2006 06:52 AM
Codes, Codes, CODES!!! patrickkdunn Contour 8 05-01-2004 04:31 PM
