Codes, codes, codes....
Car gave me 3 codes when I drove it fast:
1/3 P0102 MAF or VAF A circuit low input 2/3 P0113 IAT Sensor 1 Circuit high input and 3/3 P0113 pd IAT Sensor 1 ciruit input Erased the codes, drove again, 2 codes came back: 2/3 P0113 pd IAT Sensor 1 Circuit high input and 3/3 P0113 IAT Sensor 1 ciruit input (I have no idea what "little letters "p d" mean next to the error code. THis wasnt in the database. But second time, pd came up in Actron scanner first.) I have no idea what "little letters "p d" mean next to the error code. THis wasnt in the database. Any word on what all of this info means would be great!
Re: Codes, codes, codes....
Any mods to this engine? also make sure the temp sensor in the intake duct is hooked up.
i dont know about the pd after the code but the manuel or online manuel shoud telll you. my guess is that they are pending codes not stored codes. they are intermitent problems not all the time. (only when wot?)
1. either your IAT sensor (intake air temp) is unpluged (from changing the air filter or gutting the box.) or it had been damaged/dirty. you can remove the sensor and see if its broke or something.if you clean it just be careful not to use anything harsh on it or anything with lubricant.(electrical cleaner is good) 2. is your car overheating at all? 3. any symptoms, like sluggish car. it could be your MAF going out but there are different codes for that and usualy the car really acts up. if you want to rule that out then find a good one from a junk yard,plug it in and see if the codes come back. (a new MAF if ~$99) 4. |
I got it.. it was indeed the sensor on air intake filter container.
However, there was no noticeable performance change during the time I had the sensor disconnected.
as far as i know that sensor doesnt command the pcm to change any air/fuel trims, it just keeps the IAT monitored so you dont overheat. it may help the pcm pull/add timing to compensat for colder/hotter air. that my not feel noticable but your engine will last longer with it attached
Glad it was fixed! |
thanx for the corection, now i know
