Old 04-11-2008, 02:40 PM
Gamerxz's Avatar
Gamerxz Gamerxz is offline
Lamborghini Gallardo LP540
New project... Will take long to complete BUT i will try to as fast as possible.
Ill be doing it with this rims in the picture... SE rims in black gloss
Cheers!
Old 04-11-2008, 04:32 PM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
Re: Lamborghini Gallardo LP540
cool project.
does it seem that audi is stealing some of the lambo-ness from this though.
SCCA 7, The lost Z
Old 04-11-2008, 04:33 PM
stryfe101's Avatar
stryfe101 stryfe101 is offline
Send a message via AIM to stryfe101 Send a message via Yahoo to stryfe101
Nice!! my favorite Gallardo yet...easily the best one ever to me..I've been thinking of this as well, good luck with your build i'll be watching it for sure.
Gray
Old 04-12-2008, 12:30 AM
Gamerxz's Avatar
Big thank u to those that are following!
Made some progress... waiting for the epoxy to dry now then i can shape the body again
Cheers!
Old 04-12-2008, 12:02 PM
Gamerxz's Avatar
Update 13th apr
next layer of epoxy applied... waiting for it to dry then will proceed on!
Old 04-14-2008, 07:07 AM
Gamerxz's Avatar
Thanks to those who left a comment! I am now almost finished with the body work. some progress pictures....
After epoxy and white putty
After sanding off
After primer and some correction
Waiting for body to air out now then will continue again
Cheers!
Old 04-14-2008, 07:27 AM
stryfe101's Avatar
Now thats looking good...your really getting this done quickly! What do you plan to use for the new tail lights? Keep up the good work
Gray
Old 04-14-2008, 07:30 AM
Gamerxz's Avatar
Gray
Prob scratchbuild part by part... not sure what ill use but i think i got an idea how
Old 04-14-2008, 07:48 AM
drunken monkey's Avatar
Razor Sharp Twit
the two "frames" around the nose openings extend much further than you've made it.
from Ultimatecarpages
http://www.ultimatecarpage.com/pic.p...=1&carnum=3629
http://www.ultimatecarpage.com/pic.p...=9&carnum=3629
AF's Guidelines
Read them.
Old 04-14-2008, 07:52 AM
Gamerxz's Avatar
will take note of that thanks!~
Old 04-16-2008, 12:02 PM
Gamerxz's Avatar
More progress!
I did up the front again and shorten the front lights, this i didnt realised till i looked at the lp540 pictures closely , then i could see the difference. So it means scratchbuild front and rear lights.
I found tail pipes to fit on the car. size is perfect.
Pictures after today's progress
Cheers ! and a big thank u to drunkenmonkey for making me realise the mistakes i made!
Old 04-16-2008, 07:30 PM
Razor Sharp Twit
before you get too far.
you're probably better off making the new nose intakes from sheet plastic; easier to make them thin and more importantly, match on both sides.
Also, check the new pointed panel line on the nose. Also, the press shots aren't very good, but in some of them, it looks as if the rear of the car doesn't curve as much. You might want to hunt down some plan view to confirm is this is the case or not.
AF's Guidelines
Read them.
Old 04-16-2008, 11:10 PM
Gamerxz's Avatar
Hahaha... yeah im actually trying to smoothen out the nose then add the pointed area. Im kind of down in terms of tools . Im looking for pictures too but cant seem to find much other than the press shots which is sometimes hard to see body shape
Old 04-17-2008, 12:23 PM
KuBcZyN KuBcZyN is offline
I realy like this project couse i haven`t seen this 1:1 Lambo on thoes pics you know so i hope that every thing will be ok!!
Will you live thoes black rims on???
On your place i would paint them in silver if you living them on
But you do how you want its your Labmo M8
Nice progress!
Old 04-17-2008, 12:45 PM
stryfe101's Avatar
All you've seen is press photos?
Dude....pm me your email address....I'll see if I can't hook you up with a ton of pics from the autoshows....
plus you'll have to register here but the forums here can provide alot of info as well..
http://www.lambocars.com/forum/index.php
and I got some pics from here as well....
http://www.ferrarichat.com/forum/sho...d.php?t=149786
hope this helps....I loaded up on pics because i've been considering an Lp560-4 build myself.
Gray
