Old 02-28-2003, 11:15 AM
cscott784 cscott784 is offline
Send a message via Yahoo to cscott784
Turn signals and WIpers done work
Hello all. I was installing my alarm system, and on the left side of the steering wheel was a wire harness for the head lights. I pulled it and attached it to my alarm. There was also another one on the top of the steering wheel and a smaller one on the right. When I reconnected them, my turn signals and wipers do not work. I checked the fuse and they are all o.k. I ejected the harness and put it back in but it still does not work. The washer spray works and the hazards work. Can someone help me out and tell me what is wrong?
Thanks
SCott
Old 02-28-2003, 12:13 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Maybe you blew a fuse? Although, I know that if you don't connect your hazard switch, your turn signals will not work, so I think they may be on the same circuit... But, check your fuses anyways.
Old 02-28-2003, 01:38 PM
darolh darolh is offline
Off the top of my head it looks like you damaged the switched power in the column somehow. The hazards are on a different circuit that doesn't require the ignition to be on to run.
Just a piece of advice in the future.....pick up the power under the dash where its easier to get to ...near the fuse box is good.
Time to hit the wire diagrams and get some education.
Old 02-28-2003, 01:43 PM
Hello all. Thanks for the info. I was able to get them to work. What happened is that I did not install the indicator harness correctly. I put it on the right side above the ignition where there is a little white socket. Nothing goes there though. It is supposed to go above the harness that I use to turn on my lights. oops. Thanks though. Also, when I am done installing my alarm I would like to make a diagram and a tutorial. If anyone wanna give some info that might be usefull, just holla.
Thanks
Scott
Turn signals and flashers not working! Bill4kath Taurus | Taurus Wagon 12 11-21-2006 11:50 AM
turn signal and wiper controller fbi-interceptor Crown Victoria 1 04-30-2005 03:56 PM
Turn signals and flashers not working! Bill4kath Taurus | Taurus Wagon 0 02-23-2005 03:13 PM
need help with turn signals and wipers indebt94 '88 - '91 Civic | CRX | Wagon | Shuttlee 12 12-01-2004 08:03 AM
87 pathfinder Turn signals and gauges stopped working can't find fuse. randy myers Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 08-19-2004 02:03 PM
