Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 04-30-2005, 03:23 PM
fbi-interceptor fbi-interceptor is offline
Send a message via Yahoo to fbi-interceptor
turn signal and wiper controller
i have a 93 cvpi when i put my wipers on it seems to cut on and off if i use the turn signal or even slightly touch the controller it makes a clicking sound then if i play with it a bit it will do what its supposed to do. is the an easy fix for this or is it a major problem. lose wire maybe? problem is only with wipers though not turn signals. and
Old 04-30-2005, 03:56 PM
ModMech's Avatar
ModMech ModMech is offline
Re: turn signal and wiper controller
You need a new "Multi-Function Switch" (MFS). Should be around $80 from your local stealership, and takes around 15 minutes to replace.
