Old 02-27-2003, 06:32 PM
civic1784's Avatar
civic1784 civic1784 is offline
Popping noise under harsh acceleration
If I quickly step on the gas from a standstill or slow rolling speed in my 94 Cavalier Automatic, it lurches and there is a popping or grinding noise. What could this be caused by? However, if I am traveling at speeds over 20 and step on it, it accelerates smoothly. I'd be glad to answer any other questions that will help someone figure this out.
I was thinking that it was the A/T fluid level being too low, but when I checked it, it was fine. This car was in an accident, it was side swiped, and that might be adding to the symptoms. The steering pulls to the right. That is all I can think of for right now. Any ideas anyone?
'91 Honda Civic Hatch
Pewter Gray Metallic
Civic4g
Old 02-28-2003, 07:31 AM
Pikachoo's Avatar
Pikachoo Pikachoo is offline
Send a message via AIM to Pikachoo
sounds like the suspension maybe... if you put it in reverse and stomp on it does it pop, then pop again when you brake to stop going backwards or put it back in drive to go forwards again??
Cruising a Z24 right now, But I've got plans....
http://www.lingenfelter.com/lpe%20-%208%20sec%20Vette.mov
Old 02-28-2003, 05:20 PM
civic1784's Avatar
It only does it when I am going forward. It does not do it in reverse, and it doesn't do it when I am braking. I'm not ruling out anything, so how could this be suspension related?
Civic4g
Old 02-28-2003, 05:45 PM
bowtiebandit's Avatar
bowtiebandit bowtiebandit is offline
Send a message via AIM to bowtiebandit
Just a thought but take a look at oyur engine mounts and see if they have seperated.
Shop Foreman
Corvette Specialist
A.S.E. Master Technician
L1 Certified
A.S.E. Master Machinist
GM Certified Technician
Old 03-03-2003, 09:52 AM
Pikachoo's Avatar
I was thinking CV joints or ball joints.
popping noise when I turn steering wheel... phughes Grand Cherokee | Grand Cherokee SRT8 3 08-01-2010 03:15 PM
Tinging noise under heavy acceleration putertopia Grand Marquis 7 11-24-2005 12:41 AM
Help! Noise under hard acceleration maximagxe96 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 04-08-2004 12:36 PM
Popping noise under harsh acceleration civic1784 Engineering/ Technical 6 03-06-2003 07:21 AM
