Old 02-26-2003, 09:37 PM
appleseed's Avatar
appleseed appleseed is offline
removing chrome plating
i have no idea how to do this. would anyone like to share any techniques on how to remove the chrome plating from a set of wheels? thanks!
Old 02-26-2003, 09:39 PM
endlesskev86's Avatar
endlesskev86 endlesskev86 is offline
Send a message via ICQ to endlesskev86
spray primer??
i dunno ... but i am gonna try that though
AF OG Dori crew (member #5)
Altezzas: It only looks good if you have the FULL car, not just the LIGHTS!! grinyes:
Old 02-26-2003, 10:58 PM
sausage sausage is offline
Soak it in household bleach overnight. If it's concentrated a few minutes will do.
Recent stuff:
Singapore scale modeling site at http://machinemess.singaporeanimenews.net
Old 02-27-2003, 03:50 AM
mel79's Avatar
mel79 mel79 is offline
Liquid plumber(or whatever it's called, the liquid you use to open drains/plumbing) removes plating easily in minutes(or even seconds) and leaves plastic unharmed. Or atleast it has never attacked plastic when I've used it... Better try it on some plated sprue first.
-Mikko
Old 02-27-2003, 03:53 AM
ales's Avatar
ales ales is offline
Forza Schumacher
What he said!
Old 02-27-2003, 04:11 AM
935k3's Avatar
935k3 935k3 is offline
Bleach and ammonia work but they do not remove the clear coat under the chrome. Some paints sprayed over the clearcoat can have a reaction, I know in particular Testor's Metalizers do. Try using EZ Off oven cleaner it removes the chrome and clearcoat in about 10 minutes.
Old 02-27-2003, 06:36 AM
espin espin is offline
SIMPLE GREEN CLEANER
Craig
Click here for more pics!
Old 02-27-2003, 06:47 AM
Veyron's Avatar
Veyron Veyron is offline
I use Fantastik spray cleaner, but like 935k3 said, some model makers put a clear coat under the chrome, It seems American kit maker's do and Japanese kit makers don't. To remove the clear coat just use the usual paint stippers safe for models.
Old 03-14-2003, 06:05 PM
appleseed's Avatar
wasted time!!
i took your suggestions and used chlorine (it was readily available to me) to strip the chrome plating. took about two weeks but it finally came off. since this was the revell itr rims i'm working with, you were right about the clear coating on the wheels, veyron. so i decided to use lacquer thinner to remove the yellow 'clear' coat left on the rims. i normally use hobby thinners for thinning paints for the airbrush and regular hardware grade thinner for cleanup. being careless, i used the wrong unlabled bottle (my own damn fault!) and within minutes, the plastic began to melt! waaahhhh!!! no more wheels for my itr!!! sniff sniff....
anyone want to share a set of itr rims to a down and out modeler?
a.
Old 03-14-2003, 06:12 PM
daggerlee's Avatar
Re: wasted time!!
a.
Which set, and where do you live?
Dan
Old 03-14-2003, 06:13 PM
Jay! Jay! is offline
Horizontally Opposed
Lacquer Thinner != Safe for models. :o
Would have been better off with the usual suspects listed in the FAQ: CSC, brake fluid, etc...
Hierarchy of Subaru:
(Click to see mine!)
Old 03-14-2003, 06:19 PM
patate's Avatar
patate patate is offline
hey jay he said that he picked the wrong bottle
Old 03-14-2003, 06:32 PM
appleseed's Avatar
c'mon jay, what's that all about? i used sunnyside lacquer thinner found at a regular hardware store. this stuff is not safe for plastics as i found the hard way. looking at the originall packaging, it reads "specially formulated for use with the finest lacquers and epoxies". this should have given me an idea of how corrosive this stuff is. trying to be efficient, i ususally pour some in one of those glue bottles. this time i just happen to pick the wrong one...
a.
Old 03-14-2003, 06:37 PM
Granted, but I'm scared to use any "hobby thinners" because none of them really say what's in them... (alcohol, for example, is easy to figure out, but who knows what they add to it...)
Old 03-14-2003, 06:43 PM
daggerlee's Avatar
I think they add a bit of lacquer thinner to Model Masters Enamel Airbrush thinner. It took the Tamiya lacquer spray paint clean off my Subaru.
Dan
Removing chrome plating. KiwiBacon Cars in General 1 09-26-2007 12:53 AM
Removing Tamiya Chrome Plating.. perrisb Car Modeling 14 06-06-2007 11:07 AM
easy way to remove chrome plating tmathew1us Car Modeling 15 08-08-2006 05:00 AM
How to Chrome plate? turbos86 Car Modeling 23 07-07-2003 12:36 PM
Chrome Plated Valve Caps shortimer Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 06-17-2002 09:36 PM
