Old 08-06-2006, 03:07 PM
tmathew1us's Avatar
tmathew1us tmathew1us is offline
easy way to remove chrome plating
Many people have mentioned that the chrome plating that comes standard in many kits looks too toy-like. I have had success in removing it using scouring powder and a toothbrush. When done carefully the stripping action of the powder will removed the chrome layer but leave the details in the plastic. This is more precised than sanding the chrome off.
This technique can also be used to "scuff" a body prior to applying the primer coat. Be sure to wash thoroughly to remove all the powder.
Hope this helps
Old 08-06-2006, 07:18 PM
freakray freakray is offline
AF Modelrater
Re: easy way to remove chrome plating
Castrol Super Clean will remove chrome plating in minutes and will save you have to scrub anything.
AF User Guidelines
Old 08-06-2006, 07:36 PM
TireGaint TireGaint is offline
or household bleech! :P
FORZA FERRARI!!
Old 08-06-2006, 10:05 PM
XR6 Martin's Avatar
XR6 Martin XR6 Martin is offline
Caustic soda works well, cheap also
Old 08-06-2006, 11:08 PM
Dean23's Avatar
Dean23 Dean23 is offline
I use EASY OFF foaming oven cleaner. strips chrome in about 5-10 minutes. Works quite well
get me a hardtop with a decent engine and make sure it's got a big trunk
Dwight from Sin City
Modern cars - they all look like electric shavers
Marv from Sin City
Old 08-07-2006, 12:47 AM
quadzero's Avatar
quadzero quadzero is offline
This is what I use also. Just make to sure to wash the part with plenty of water.
Old 08-07-2006, 01:27 AM
ajthomas75 ajthomas75 is offline
Vote one more for Oven Cleaner....... Works a treat, Chrome just almost disappears.....
Adam.
Old 08-07-2006, 02:24 AM
tmathew1us's Avatar
As we see, there is more than one way to strip a part. I do prefer the scouring powder method since that is the only one that you don't need gloves/eye protection for.
To each their own!!
Old 08-07-2006, 05:13 AM
klutz_100's Avatar
To each their own!!
I don't agree with that at all.
1. You should ALWAYS wear eye protection when working with chemicals or hazardous materials.
2. When you are scouring, there is more risk of something flying into your eye from the bristles of your toothbrush.
3. If you feel you don't need eye protection for scouring powder, then for sure you don't need them to drop a chrome part in some bleach or a bag with oven cleaner (a mask is advisable here though).
4. Rubbing with scouring powder SOUNDS like just about the most bothersome method of removing chrome I have heard of. With the most sincere and best meant intentions, I really suggest you try our some of the other methods mentioned above (also rubbing alcohol apparently) - I think you will be pleasently surprised by the results.
5. Thanks for taking the time to want to share your thoughts and ideas with us - it's what a forum is about!
6. I DO agree with you on "each to their own"
Old 08-07-2006, 11:19 AM
Rtuned's Avatar
Rtuned Rtuned is offline
But remember to wear a glove before touching the bleech. The bleech really smell bad on your hands, ladies will run away...
Old 08-07-2006, 03:52 PM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
olly olly oxen free
Old 08-07-2006, 07:50 PM
speener's Avatar
speener speener is offline
Now the question becomes what do u paint these parts with that it looks better than the stock chrome plating?
Old 08-07-2006, 08:46 PM
winstona's Avatar
winstona winstona is offline
You can use Alclad II chrome for that. However, it may not look better than the stock chrome in terms of the finishing.
The thing about stock chrome is that most of the time, the plastic underneath near the tree area will show when you cut the part off the tree. You then end up with a situation where you have to touch it up with something that won't match the original chrome paint. You will not have a perfect finish in this scenario either...
Winston
Old 08-07-2006, 09:13 PM
MidMazar's Avatar
MidMazar MidMazar is offline
Purple Power!!!
In Progress
Old 08-08-2006, 01:06 AM
Hash_man's Avatar
Hash_man Hash_man is offline
I thought I remembered people talking about using brake fluid to strip paint and chrome.
I was gonna try that tommorow.
