Old 02-26-2003, 07:54 AM
AudioHead AudioHead is offline
Shifting into 2nd
Is it just me or is this a common problem to grind a bit when shifting into 2nd? It's probably me but I had the same problem with my 91 si? or maybe some thicker oil in the trans might help.
Same dream, New car.
Old 02-26-2003, 08:03 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
Sounds to be like your syncromesh is going int he gearbox, a syncromesh basicaly lets you change gear without the gears grinding but when you try to change gear at high revs or quickly and the sycromesh it gone it will grind when u try to put it in gear
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 02-26-2003, 09:35 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Yeh sounds like your synchros.
Old 02-26-2003, 10:00 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Thumbs up
My tranny grinds going into 3rd...even if I double clutch...I hear that "GM Synchromesh" tranny fluid helps a lot..I checked my local GM parts counter and they have it for $9/quart...I just need to go get it and put it in when the weather gets better - I love snow, but I am ready for spring!!
Edit - http://gmpartsdirect.com has it for $5.65/quart...the GM part # is 12345349 .
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
Deal with it or get a tranny from the junkyard.
Old 02-26-2003, 12:53 PM
jam4484 jam4484 is offline
Send a message via AIM to jam4484
i had the same problem with my accord before it went. i drove it for a long time lik that until it finally went then i picked one up from the junkyard for pretty cheap and threw it in. if uw ant put some oil in or just deal with it really.
1989 Crx Si
-Aem cold air intake
-thermal cat back
-test pipe(makes exhaust sound really bad)
-Skunk2 short shifter and knob
-Hx wheels
-Tenzo front and rear strut bars
-parts waiting to go on- nuespeed header
-waiting to be built-my spare a6 block, with y8 head, 93 valve cover, z6 intake manifold, integra tb....
Old 02-26-2003, 01:19 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Mine does the same thing some times, not all the time though, just when I try to shift really quick, usually its my error, sometimes its not though.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 02-26-2003, 01:20 PM
I actually think it's a defect!
Old 02-26-2003, 02:13 PM
turbcivic's Avatar
turbcivic turbcivic is offline
Tranny rebuild!!
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
95 k1500 wont shift into 2nd.. found melted solenoids coreman30 C/K 9 01-18-2011 04:24 PM
Please Help, '99 AT Mitsu Eclipse won't shift into 3rd '99EclipseProblems Engine, Transmission and Drivetrain 6 09-13-2009 10:03 PM
'99 Blazer Transmission Shifting into 2nd and 3rd gear at High RPMs amazonpup Blazer 9 09-02-2004 09:32 PM
Why Cant I shift into 2nd!?!?! wheel1856 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 20 05-06-2003 08:46 PM
hard shift into 2nd on auto trans G20 quakerstl Maintenance 3 03-25-2003 10:01 AM
