Old 05-02-2003, 07:31 PM
wheel1856's Avatar
wheel1856 wheel1856 is offline
Send a message via AIM to wheel1856
Why Cant I shift into 2nd!?!?!
Ok, today I've had it! I put in a short throw shifter about a year ago, ever since then, I grind second. I learned how to drive on a 5 speed, and all my cars have been a 5 speed, I've been driving stick for 9 years and I know the grinding that comes from 9 out of 10 shifts into 2nd gear aint cause of me.
Now, I down shift ALL the time when I brake. The clutch should be fine because I never have problems in any other gear, or getting back down into them. I do occaisionally have problems getting down into second, but nothing major.
so...WTF!?!?! why can't I shift into second!?! RPM's seem to not matter either, I gotta shift it like a semi to not grind it? Do the short throw mess up the linkage somehow? How would I fix it?
thanks again all, I really wasnt gonna worry about it, but its really startin to get to me, plus every time I shift after a light I look like a dick, and well that just sucks. ( no punn intended)
"Why yes, this is a GS-R."
Old 05-02-2003, 07:46 PM
Kill4A911's Avatar
Kill4A911 Kill4A911 is offline
Send a message via AIM to Kill4A911
worn out sychros maby? if double clutching helps then thats probably it its
Civic:selling the D16Z6 getting ready for a B16 turbo
240Z:was thinking about a VG30DETT but am now looking at a V8
Old 05-02-2003, 08:54 PM
94tegRS's Avatar
94tegRS 94tegRS is offline
yeah, sounds like syncros, mine were bad in 3rd on my integra(bought it like that tho) and a friend of mines car does it into 2nd. but he and I didnt ever fix it yet, and it still goes into the gear, just makes some noise, but I hate driving a car around town and letting everybody hear my car grind and think I dont know how to drive.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 05-02-2003, 09:41 PM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
bah, its cuz "ur granny shifting an not double clutching like u should" :hehehe:. u said no other gears rite? cuz if its more then one, could be a master cylinder or slave unit, or something as simple as no clutch fluid.
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 05-02-2003, 10:23 PM
liquid8 liquid8 is offline
Send a message via AIM to liquid8
mine does that too but only when i shift at 6000 an above quickly. if i shift slow it doesn't do it
"life's a bitch but god forbid the bitch divorce me" - nas
Old 05-02-2003, 10:25 PM
Kill4A911's Avatar
bah, its cuz "ur granny shifting an not double clutching like u should" . u said no other gears rite? cuz if its more then one, could be a master cylinder or slave unit, or something as simple as no clutch fluid.
yea yea i know i hate the fast and the furious too and double cluching is worthless, UNLESS... your sychros are messed up in which case if you rev match and they dont grind then you have your answer.
Old 05-02-2003, 10:41 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
umm maybe its time for tranny fluid change ?
Team Lonely Drivers
Old 05-03-2003, 01:07 AM
wheel1856's Avatar
yeah see tranny fluid was my first thought, drained and replaced that...no love. And it is only one gear, just second. And when I do manage to pull off a flawless (or at least one that those not in the know would think was flawless) double clutch, it doesnt grind.
tell me more about these synchros...I do not know these ways. or gimme a link so I can learn my damn self. is it a driveway fix? or a real mutha of a problem? if I have to re-build the tranny...f*ck it, the swap is just around the corner and that'll be a new tranny, so...
and yeah, fast and the furious, oi, double clutch while accelerating in a straight line, dumb dumb dumb
thanks all.
-wheel
Old 05-03-2003, 01:55 AM
92teggsr 92teggsr is offline
You're probably better of replacing the whole tranny cause synchros are a bitch. You have to get into your transmission and there is so much crap in there it's like impossible to do yourself. Plus it'll probably cost more to have them fixed than getting a new tranny. Mine grinds into second and third sometimes but it won't do it when I double clutch it either. I hate it.
Now if your synchros are only grinding at high rpm then that means it's just the beginning. they'll get worse. So my take on this is: get a new tranny and try to sell the old one for cheap. That's what I'm doin.
99 Honda Civic Si
Stage 2 Clutch
SPP Exhaust
Short Shifter
Eibach Suspension
17's
91 Honda Accord LX
Old 05-03-2003, 04:46 AM
ONLY dumb on cars w/ syncros. the older cars, taht was the only way u could get ur car into gear at higher rpm.
simplistic terms, the syncro's basically help u put ur car into gear an line up the teeth of the clutch to the blah blah blah...jus kno they help u get into gear. if u want the entire story about how they work, then check out www.howstuffworks.com
2003 Infiniti G35
Old 05-03-2003, 02:34 PM
wheel1856's Avatar
word. wasnt that because the hydro trannies werent that great yet, and the second cluth helped up the fluid pressure to make the shift smoother?
and yeah, if taking the tranny apart is the fix, screw it, the b16 is only a month away, I can live with it until then.
Old 05-05-2003, 01:18 AM
SiRII's Avatar
SiRII SiRII is offline
it can be your clutch, your gear box, or mostly a boot on the short shifter. it got that same problem in 2nd and sometimes 3rd. but, i just need to change the shift boot.
Old 05-05-2003, 06:50 PM
Kill4A911's Avatar
so your saying the shift boot is making the gears grind...?
Old 05-05-2003, 06:52 PM
SiRII's Avatar
well, ya. i was told that when i did the swap. that the boot need to be replaced. if 1 bolt is missing or the rubber is worn out then it wont engage the gears right.
Old 05-05-2003, 07:33 PM
Kill4A911's Avatar
the boot doesnt have anything to do with engaging the gears thats the stick and linkage, are you talking about the bushings or something?
95 k1500 wont shift into 2nd.. found melted solenoids coreman30 C/K 9 01-18-2011 04:24 PM
Please Help, '99 AT Mitsu Eclipse won't shift into 3rd '99EclipseProblems Engine, Transmission and Drivetrain 6 09-13-2009 10:03 PM
96 Sunfire GT M/T cant shift into 2, 4, or R briand212 Cavalier Problem Diagnosis 7 04-16-2006 06:04 PM
1992 Camaro Z28 cant shift into 2nd nicochristino Camaro Discussions 3 03-18-2005 10:08 AM
hard shift into 2nd on auto trans G20 quakerstl Maintenance 3 03-25-2003 10:01 AM
