Old 02-25-2003, 04:05 PM
fullbloodchop01's Avatar
fullbloodchop01 fullbloodchop01 is offline
Send a message via AIM to fullbloodchop01
your putty preference
ive seen many different types of putty mentioned on this board and i just want to know what your preference is?
i have used manyb different types of putty like: bondo body filler, bondo spot and glaze, squadron white, tamiya basic grey, and wood filler. the bondo car filer is good, if you have big spots to fill, or even small spots but it is VERY messy. Bondo spot and glaze putty is very good IMO, only problem is that it is easily sanded, like it seems not to stick to the body as well as others, squadron is ok, as it develops TOO many pin hole when dry and sanded, tamiya is also a good putty to use and is recomended, and as for wood filler, well its wood filler, what else can you say
so i would have to say it is a tie between bondo spot and glaze putty and tamiya basic grey
Rui
(modeling) = Click Here
Old 02-25-2003, 04:10 PM
JDM Evo7 JDM Evo7 is offline
As of right now I like the following.
1. Gunze Dissolved Putty - filling small seam lines, bumps, etc..
2. Mori Mori Polyseter Putty for larger areas, shaping, smoothing
3. Tamiya putty thinned with lacquer thinner for texturing
4. Gunze epoxy putty for styling, modeling complex shapes
Current Projects: HGUC Gelgoog Cima Custom, DC5 ITR "Cusco + Spoon show car", HKS R-32 Gr. A Skyline
Old 02-25-2003, 04:14 PM
supratuner's Avatar
i can only get testors putty, so i use red putty, for making body kits, and contour putty for the small areas
Old 02-25-2003, 04:46 PM
Vric's Avatar
Vric Vric is offline
I use Bondo Putty (car putty) work really great
Old 02-25-2003, 04:52 PM
SirWelshy's Avatar
SirWelshy SirWelshy is offline
uses milliput 2part putty, its great u can mold it as one applys it to the job one is doing, ......plus u can crave it when its dry
todo -->> Dan Finks speedwagon, taurus, lotus 107, `60 chevy hardtop, austin martin db6, austin healey 100-six, datsun 610? and bmw
http://www.pearce.50megs.com/model.htm
Old 02-25-2003, 04:54 PM
Modelcargarage's Avatar
Modelcargarage Modelcargarage is offline
Send a message via AIM to Modelcargarage
i have....
i have researched and found that most people prefer the car bondo because it is very easy to work with yes you may get e little messy but thats the fun of building model right?
Old 02-25-2003, 05:43 PM
flyonthewall's Avatar
Car Mod guy
I've not used many putties coz they are not readily available in the UK, i have one of each of the Tamiya types on order to try them out though. But anyway, i do ok with my good old Humbrol Model Filler, Milliput has its uses but a rarely have need for it. I also have some Stucco putty which is less viscous than the Humbrol stuff so is good for filling small imperfections.
Old 02-25-2003, 06:13 PM
Ayala's Avatar
Ayala Ayala is offline
i like to use tamiya two part quick and plain putty, it's very versatile to use on any project IMO. the worst putty that i've used was milliput, juz hate it!
Old 02-25-2003, 08:05 PM
endlesskev86's Avatar
endlesskev86 endlesskev86 is offline
Send a message via ICQ to endlesskev86
i got the testors contour putty and they work great at smoothing out the parts! highly recommend this stuff.... also there is this other brand...(i think its called MR.Putty , Japanese stuff) Works really WELL.... Crazy Cheap too.... like 10 HKD... whihc is about 2 bucks Canadain
AF OG Dori crew (member #5)
Altezzas: It only looks good if you have the FULL car, not just the LIGHTS!! grinyes:
Old 02-25-2003, 08:10 PM
64 Chevy 64 Chevy is offline
well the only kind i have tryed and i guess it would be my preference cause i havent used anything else is the JB Weld Quick set 2 part epoxy. So far it has worked well for me but i cant compare it to any thing.
Why can't I think of any thing clever to put down here?
Old 02-25-2003, 09:49 PM
COZMO6476's Avatar
COZMO6476 COZMO6476 is offline
ive used:
-testors contour... too gritty for my taste and doesnt sand smooth for nothin'
-testors Red putty... pretty good stuff... much better than the contour putty. reasonably smooth after sanding
-tamiya basic putty... pretty good stuff but my tube dried out quickly sands smoothly but is much harder than testors so it requires more sanding to smooth it out.
-tamiy epoxy putty (smooth)... dont like it. it doesnt hold details well and tends to smooth them out, hense the name. the putty also is quite soft after it cures. not good for body kits since it is flexible even after it has completely cured. its like old chewed gum IMO. sanding it is just like sanding an old dried piece of chewed gum.
-Tamiya epoxy putty (quick)... my favorite since it made my bomex bumper possible. it cures hard which is great for sanding. it can be brittle if you are too rough with it but is still relatively strong stuff once it has cured.
hope that is somewhat helpful.
Old 06-07-2003, 08:54 PM
subyfanatic's Avatar
subyfanatic subyfanatic is offline
BiggE
Question-
I notice for some putty there is a hardener available. Example- Sube Sube and Mori Mori both make Polyester putties and then they make a putty and a putty hardener. Does this mean polyester putty can be used as a stand alone or is the hardener required? Also, any opinions in regards to these?-
Doro Doro
Sube Sube
Mr. Light Weight Epoxy
Mr. White
Thanx,
E
"Follow the white rabbit."
Old 06-07-2003, 10:18 PM
935k3's Avatar
935k3 935k3 is offline
First of all I to use as much plastic in gaps,holes etc. before resorting to putty.
For smaller gaps etc. I use Bondo Glazeing spot putty(red stuff)by the way it's the same as the Testor's red putty but the Bondo is about 1/3rd the price.
For larger holes,gaps and contouring I use Dynatron Puttycote, a very fine grain,high grade Automotive putty(two part type)sold at Automotive Paint supply shops. It feathers better than any thing I have ever used and it has styrene fillers in it. You can glue plastic over it if necessary.
If use you use Bondo two part filler try their higher grade Bondo Ultimate sold at Auto Parts stores. Regular Bondo is a little corse, the Ultimate is finer grain.
Old 06-08-2003, 10:13 AM
suicideclipse's Avatar
suicideclipse suicideclipse is offline
i can't believe that no one mentioned model master red putty. this stuff is great for filling in small inperfections, and small pin holes.. it's easy to apply, and is even easier to sand. i also use bondo, and squadrin white, and green.. jason
Old 06-08-2003, 03:06 PM
Camber's Avatar
Camber Camber is offline
Send a message via AIM to Camber Send a message via Yahoo to Camber
Thats the same thing as Testors red
wich blow off valve would you prefer for your vr4 or rt/tt? 6g72tt 3000GT/Stealth 5 05-03-2005 02:55 PM
what is your preferred method for changing body color/paint? CrazyModGSR Graphic Manipulation 4 02-04-2004 12:58 AM
Putty? Puh-ty? PUTTY?! DiGiTaLEcLiPsE Car Modeling 2 10-21-2003 03:05 AM
