Old 02-25-2003, 08:10 AM
bart8016 bart8016 is offline
Tamiya Compound
Ok, just got my compound today. But my question is: Before you apply the compound you have to sand the body but must that be done wet??
Can I put after that the Compound on?
Greets Bart
Greets,
Bart
Old 02-25-2003, 09:51 AM
The Lambrusco Kid's Avatar
The Lambrusco Kid The Lambrusco Kid is offline
AF Premium User
Here's what I do.
I sand the body with 1200 grit paper, after that 1500 and then finish with 2000 grit paper.
Then I rub the body with the compound with a soft coton cloth.
You may have to repeat the rubbing process to get a very good mirror-like shine. If scratch are still visible, re-sand and re-polish.
Good luck.
(I wasn't sure the first time I tried, but it turned out okay )
__________________________
"Back off man, I'm a scientist."
Click banner to view thread
Old 02-25-2003, 02:29 PM
JDM Evo7 JDM Evo7 is offline
If you wet sand you will have less build up on the sand paper, which will make it last longer. It also helps(but does not eliminate) to lower the possibility of gouging the paint. I would start with 1,500, then 2,000, and finish with 4,000 before rubbing compound.
Old 02-26-2003, 01:09 AM
Thanks for the answers. I think I'm going to sand it wet.
Bart
Greets,
Bart
Old 02-26-2003, 01:12 AM
primera man's Avatar
"P-Man"
Re: Tamiya Compound
Greets Bart
If there is no orange peel and the paint is almost perfect....dont bother sanding. Just compound
View All My Models Here.
Old 02-26-2003, 01:28 AM
Thanks that is much easier en faster to do than sanding the whole body.
Bart
Greets,
Bart
Tamiya Compound?!?! fullbloodchop01 Car Modeling 7 01-12-2003 08:25 AM
1/1 Polish or Tamiya Compound/Wax? Camber Car Modeling 2 12-12-2002 04:17 PM
Proper Way to use Tamiya Compound/Wax? Camber Car Modeling 2 11-29-2002 03:17 AM
Tamiya Compound CalsonicR34 Car Modeling 4 09-29-2002 10:19 AM
What should I use to apply Tamiya Compound JE123 Car Modeling 3 01-31-2002 02:24 AM
