Old 02-20-2003, 10:51 AM
90civichatch 90civichatch is offline
Send a message via AIM to 90civichatch
car wont start
My car has a new dizzy, has good compression and fuel pump works. It has strong spark I checked the main relay and all the fuses, and the ECU is NOT throwing any codes. When I try to start it, it back fires and gray smoke comes out of the throttle body.
...i need some help
1990 Honda Civic Shit-box, Sold.
Old 02-20-2003, 10:53 AM
91civicDXdude's Avatar
check your timing.
Old 02-20-2003, 10:58 AM
The car was running then just stopped. I checked the timing belt. it is in good shape and hasnt jumped any teeth.
Old 02-20-2003, 11:45 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
check your fluids, you might have siezed the engine
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 02-20-2003, 12:15 PM
I checked the fluids, gots plenty.
Old 02-20-2003, 01:22 PM
turbcivic's Avatar
turbcivic turbcivic is offline
Check your firing order. Is is MPFI? Yous might have fuel coming from the fuel pump but all the injectors might not be working, so check each injector.
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 02-20-2003, 01:30 PM
I got a DX with DPFI. How can i check the injectors
Old 02-20-2003, 01:34 PM
turbcivic's Avatar
At work i have a probing sethscope i put on the injects, just use a long flatheaded screwdriver, put it on the injector and put your ear on the screwdriver. An injector will make a very fast ticking sound as it pulses.
My Fiat Punto Car Wont Start Ilhanx64 Punto | Idea | Punto Grande 2 10-21-2010 06:14 AM
Car wont start ethan-erickson0015 '96-'00 Civic 3 04-24-2010 10:22 PM
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
(94 1.8) car wont start, turns over but wont start. billclinton Corolla/Matrix/Voltz 2 11-09-2004 12:02 PM
