Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 04-19-2010, 10:27 PM
ethan-erickson0015 ethan-erickson0015 is offline
Exclamation Car wont start
1997 Honda Civic Ex Sedan. Engine light came on about five months ago for a misfire on cylinders on 2,3,4. i Cleared the code and the light stayed off until now. Light came back on for a miss in 2,3,4 i cleared the code again and went to start the car it wouldn't start. It has spark on all four cylinders distributer is good. Compression is normal fuel pressure is good. Timing is good. Even tried dumping fuel straight down the cylinder didn't even get a pop but i could have just flooded it though. I was thinking that it could be the crankshaft sensor but I'm not sure car doesn't have a cam sensor. Any ideas would be appreciated i am at a loss for ideas. Thanks Ethan
Old 04-23-2010, 11:46 PM
BishiRST BishiRST is offline
Re: Car wont start
I would look into the Dizzy again, maybe replace it with a known good part cuz sometimes the magnetic pick up will go out on them.. also look inito your injectors, see if the ECU is turning them on while you crank, if you have or can put hands on a noide light that'll help out a lot, if not, just try using a test light on the wires while cranking. But by the sound of it, its defenately electrical!!
Old 04-24-2010, 07:58 PM
Re: Car wont start
The injectors are getting a ground signal from the icm. What would cause the distributor to go back just normal wear or did something cause it.
Old 04-24-2010, 10:22 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Re: Car wont start
You have air, fuel, spark and good compression. It should start. Maybe mixture is too rich.
I don't think it's the CKP sensor, cause you have both ignition and fuel.
Have you tried to accelerate to the floor when you start?
Check MAF and IAT or MAP and MAT sensor. Depanding of what your car is equipped.
Check plugs condition to see if you don't have oil/carbon deposit or too much fuel smell. Cause maybe it's burning oil.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Tags
civic , engine , honda , misfire , start
