Old 02-10-2003, 01:59 PM
ChopinPorkChop's Avatar
ChopinPorkChop ChopinPorkChop is offline
Send a message via ICQ to ChopinPorkChop Send a message via AIM to ChopinPorkChop Send a message via Yahoo to ChopinPorkChop
is any old compressor fine for an airbrush?
My Msn: [email protected]
Old 02-10-2003, 02:04 PM
JDM Evo7 JDM Evo7 is offline
It depends on application. This is a good compressor for cars, planes, and anything where you need nice even and uniform application. I build tanks now and some of those have very intricate camo schemes with very fine lines. For that I need something with a pressure tank to sustain really high pressures, around 40-60psi for that level of detail work. But to put it in comparison, the compressor I will be getting costs almost 400 dolalrs.
Old 02-10-2003, 02:49 PM
God|Zilla168's Avatar
God|Zilla168 God|Zilla168 is offline
JDM if you are in the states go to wall mart and get a compressor for 99 bucks. Has a tank and everything
Current project:
Mclaren MP 4/18
Old 02-10-2003, 02:53 PM
Those are way too loud for indoor use, and way too big.
Old 02-10-2003, 03:15 PM
Mainomega Mainomega is offline
Thats the compressor I use right now. It has a 1 gallon air tank. Its not nearly as loud as regular compressors, but its stilll loud. I put mine in the closet, set the pressure, turn it on and close the door.
I'm looking for silent types so i can airbrush with out bothering my GF or scaring my cat, but they are so expensive.
Got Something Good ? E-mail me
Old 02-10-2003, 03:19 PM
This is a very quiet compressor, right around 60db or so when on
Old 02-10-2003, 05:25 PM
flyingmachine flyingmachine is offline
I use to use the same setup. Walmart here at Sacramento has it at $80 right now. Hooked mine up w/ a 7 gal tank($14 @ walmart) also, w/ 8 gal of 120psi total, I could do an entire night of shooting w/out turning on the compressor again.
Old 02-10-2003, 05:32 PM
BTW, just remembered that a friend of mine w/ the same setup rigged a frige compressor to his for another $100 at a professional shop using a used frige compressor off ebay. So for around $200 he got himself a nearly quite setup w/ plenty of pressure to play w/.
Old 02-10-2003, 06:18 PM
Size though is a major consideration for people like me and other. I can't dedicate a lot of space. Los Angeles real estate prices are a little high! I don't have a lot of space in my house.
Old 02-10-2003, 08:06 PM
daggerlee's Avatar
I'm curious, what kind of camo requires 40-60 PSI? I thought for fine control and lines, the lower the PSI and thinner the paint is, the more control you get.
Dan
Old 02-10-2003, 08:25 PM
Sidewinder-03's Avatar
Sidewinder-03 Sidewinder-03 is offline
I use a portable air tank with a pressure reg.,pressure gauge, and water trap,and a quik release coupling installed.It's quiet,light,and only cost 25 cents to fill up at the gas station.I got lucky and found mine at a yard sale for $25.
Old 02-10-2003, 09:47 PM
How much PSI will the gas station give you for 25c ?
How did you hook up the extra tank. Is there and inlet and a regulated outlet ?
This seems like a good idea
thanks
Old 02-10-2003, 11:57 PM
chaos's Avatar
chaos chaos is offline
AF Premium User
It seems a lot of modellers favour the Walmart ones. But, we don't have a Walmart down under - just wondering - any Australians out here come up with a reasonably priced setup?
Old 02-11-2003, 09:37 AM
The Walmart compressor comes w/ a universal outlet/hose, and the tank has a tire chuck in(w/shut off) and a outlet for inflating stuff. I don't have the setup infront of me right now, but I remembered I took out the inflation hose and connected a 2 port outlet w/ quickrelease to it. One of the outlets went to the compressor and tank, the other one had a pressure regulator and the airbrush. I remember I was able to hook up two airbrushes to it by switching the components around also. Homedepot should have everything you need. This for me was the perfect setup since the airtank can be easily disconnect for airbrush on the go, or autoX.
Old 02-11-2003, 10:56 AM
daggerlee's Avatar
Here's the Walmart $100 compressor with my setup. I used a simple 1/4" to 1/4" "nipple" (that's what the guys at Home Depot called it) to connect the airbrush hose to the compressor. It was like, a dollar or something really cheap. The bigger, larger gauge is the pressure gauge, and the smaller gauge is the tank pressure gauge. Whenever the tank pressure falls below 75 PSI, the compressor starts up again (if it's turned on). Definitely a good buy for only $100.
Dan
airbrush/compressor stuff Integra14 Car Modeling 9 09-02-2003 02:30 PM
which airbrush compressor elvinKee Car Modeling 3 09-02-2003 09:44 AM
Airbrush Compressor Question fullbloodchop01 Car Modeling 7 08-07-2003 02:30 PM
Airbrush Compressor for Sale JDM Evo7 Car Modeling 4 02-10-2003 06:22 PM
Airbrush Compressor problems? UncleMeat777 Car Modeling 2 06-18-2002 06:14 PM
