Old 06-18-2002, 04:28 PM
UncleMeat777's Avatar
UncleMeat777 UncleMeat777 is offline
Send a message via ICQ to UncleMeat777 Send a message via AIM to UncleMeat777 Send a message via Yahoo to UncleMeat777
Airbrush Compressor problems?
My compressor gave out today. I don't know why, hopefully someone does.
I was spraying normally, and it started getting really hot, and shut off. I don't know if this is a safety thing or what, as it came with no real instructions.
I'll have to dig up the brand (it isn't on the compressor) but it's a standard noisless, tankless compressor. Got it at the hobby shop, best one there. :-/
'91 VR-4 - not running
'02 Hayabusa - winter storage
'03 WRX - running
Click here for my site and 1:24 car pics!
Old 06-18-2002, 04:47 PM
astroracer's Avatar
astroracer astroracer is offline
Does it have an on/off switch or do you just plug it in to fire it up? If it's a plug in deal I doubt there is a circuit breaker on the compressor anywhere. I'll bet you popped a breaker in the fuse box. If that's the case you shouldn't run the compressor from the wall outlet or, if you were using too small of an extension cord, get a bigger one. Any of these will cause a large current draw and pop a breaker. Check it out and get back to us...
Mark
Old 06-18-2002, 06:14 PM
Hmph, turned it on after letting it sit for about 45 minutes, and it works fine. Must have some sort of safety mechanism in it, because I was using it for quite a long time and it was getting aweful hot.
'03 WRX - running
