Old 02-10-2003, 04:34 PM
90civichatch 90civichatch is offline
Send a message via AIM to 90civichatch
civic wont start NEED HELP
fuel pump is working and it has strong spark. what else could cause this problem. Is there any thing easy i could check?
1990 Honda Civic Shit-box, Sold.
Old 02-10-2003, 04:36 PM
Civic Rush's Avatar
Civic Rush Civic Rush is offline
Send a message via AIM to Civic Rush
check your ecu to see if it is throwing any codes
This is the real melt pizzle
Old 02-10-2003, 04:59 PM
checked the ECU.. no codes. What else could be the problem?
Old 02-10-2003, 05:00 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
just because fuel pump is working, doesnt mean fuel is getting into the combustion chamber. maybe clogged fuel line, or clogged fuel filter or injectors
Old 02-10-2003, 05:12 PM
how can i check for clogged fuel lines or injectors?
Old 02-10-2003, 05:28 PM
91BLKsi 91BLKsi is offline
Send a message via AIM to 91BLKsi
whats up?..its your distributer, thats what happened to me like twice already..i just got my car out the shop saturday...IM telling its your distibuter. U need a new 1 or get the 1 that u have rebuild
Old 02-10-2003, 05:30 PM
The car has strong spark, and i just got a re-built dizzy just a month or two ago.
Old 02-10-2003, 05:59 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
I heard once that a way to see if your injectors are working properly is to do as follows: Turn your car on. Take a flat head screwdriver and put it on the injector(anywhere on it) Put your ear on the handle of it and listen to see if you can hear them spraying or not.
Ive never tried this but I figured you may want to give it a try.
Old 02-10-2003, 07:12 PM
..anything else?????
Old 02-10-2003, 08:13 PM
....any help?
Old 02-10-2003, 10:36 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
If you can give me more symptoms on the problem i could troubleshoot it for you. Is it turning over..Is it clicking..Is your fusebox getting power..Is the rotor inside the distributer still good..
I'm taking this stuff in school right now so i might be able to help you out.
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 02-11-2003, 09:11 AM
Yes it is turning over, and has power. fuel pump works and has spark. Just got a re-build dizzy not too long ago.
Old 02-11-2003, 02:25 PM
turbcivic's Avatar
turbcivic turbcivic is offline
check compression. it takes three things for the engine to run, fuel, spark, compression.
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 02-11-2003, 05:22 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
it takes air too...
but you should check your timing too... the belt could have jumped a few teeth causing you grief...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 02-12-2003, 06:11 PM
I checked the timing belt. It is still in timing and in good shape. I also checked the main relay and that works fine. What else could be the problem?
WONT START, need help fig. out what the hose is 4 mrs.k.m.ashby Grand AM 0 02-12-2011 05:07 AM
98 Grand Prix Wont Start, need help ASAP! atdudonis Grand Prix 3 06-17-2010 08:57 AM
91 civic wont start....PLEASE HELP!!! civic91zcdohc '88 - '91 Civic | CRX | Wagon | Shuttlee 1 03-23-2005 10:12 PM
1995 camaro wont start need help!!! llbigj04 Camaro Discussions 1 02-06-2004 11:00 PM
Car Wont Start, Need Help Asap!! branman_crx_guy '88 - '91 Civic | CRX | Wagon | Shuttlee 3 06-16-2002 08:53 PM
