Old 02-08-2003, 02:34 PM
SlammedCivicSedan's Avatar
SlammedCivicSedan SlammedCivicSedan is offline
Send a message via AIM to SlammedCivicSedan Send a message via Yahoo to SlammedCivicSedan
Cam Gears
hello everyone,
if i get a obx or aem cam gear, will that produce any more horsepower and what is a carm gear for anyway?
i have a 99 civic sohc engine.
thanks
I have a aem cai, and im getting dc sports headers and a hi flow cat to accompany my 2.25 custom cat back muffler.
Rattltrunk
Cardomain
2007 Mazda Mazda3
2003 Suzuki Aerio
[email protected]
Old 02-08-2003, 06:27 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
cam gears can give you or lose you HP if you dont know how to tune them, without a dyno to tune it on, you'll be doing alot of driving, changing setting, driving, change setting, etc.
cam gears attach to the end of you camshaft and can be adjusted to either retard or advance the time that your valves will open or close. But you will need to have someone do it for you at a dyno or do it yourself if you have enough experience.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 02-08-2003, 08:11 PM
so how much gains should i get with one and which brand is the best?
i heard that to get the ones with 4 or more bolts so it wont slip off.
Rattltrunk
Cardomain
2007 Mazda Mazda3
2003 Suzuki Aerio
[email protected]
Old 02-08-2003, 10:49 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Unhappy
You will not see much at all. The primary purpose of the cam gears are to change valve overlap, which you cannot change on a sohc motor with cam gears . I would spend the $ on something else.
Old 02-09-2003, 07:31 AM
aight whtteg, you seem to know alot, tell me some inexpensive things to get to improve my SOHC engine a bit.
Thanks
Rattltrunk
Cardomain
2007 Mazda Mazda3
2003 Suzuki Aerio
[email protected]
Old 02-09-2003, 07:47 AM
how bout some accel spark plug wires and ngk spark plugs?
will that help out some?
which spark plugs are good?
what else can i do for my engine, N/A, no turbo or supercharger shit.
Rattltrunk
Cardomain
2007 Mazda Mazda3
2003 Suzuki Aerio
[email protected]
Old 02-09-2003, 01:21 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
you can up the comp ratio to like 11.5, put a big camshaft in there, then a cam gear, high flow intake mani, bored tb, port polish, high flow fuel rail, pressure regulator, bigger injectors, if you getting bigger cam, then you should upgrade your valvetrain, and if you up your comp ratio then youll probably getting pistons, then might as well deck the block and get rods too, knifedge the crank, actually most all motor engine are bored out, that would help. theres more stuff you can do, but i got lazy, so yeah thats a few things you can do
Old 02-09-2003, 04:25 PM
i got lost on the first word....duhhhhh
Rattltrunk
Cardomain
2007 Mazda Mazda3
2003 Suzuki Aerio
[email protected]
Old 02-09-2003, 09:42 PM
whtteg's Avatar
Question
How much are you looking to spend? The things civickiller mentioned are not cheap. IMO the best hp jump for the money is nitrous. Ok alot of ppl say " no, don't use nitrous it will bolw your motor" . Well they are right in that if you fail to educate yourself about it and how to use it first. You could prob. run a 50 shot with absolutely no problems what so ever. But if you want power on demand all the time you will have to drop some serious $.
You can probably find a camshaft, possibly srings and retainers, a intake manifold and a fuel pressure regulator. That would help quite a bit. The fuel rail and injectors are not needed, the stock ones will support more power than you will be adding with these things. Is your car a five speed? If so then a light weight flywheel (I suggest chromoly, not alumn.) will help add a little pwer as well as increase the acceleration of you car. Also a set of underdrive pullies will increase the power a little but not significantly. Hope this helps, let me know if you have any more ?'s .
Old 02-10-2003, 06:26 AM
that all sounds good i just need to meet someone close to where i live so i can hook my shit up.
Rattltrunk
Cardomain
2007 Mazda Mazda3
2003 Suzuki Aerio
[email protected]
Old 02-10-2003, 10:12 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
I wouldn't get cam gear if you dont have upgraded cam for your car.
Old 02-10-2003, 11:39 AM
upgraded cam shaft?
what would that do for my engine?
Rattltrunk
Cardomain
2007 Mazda Mazda3
2003 Suzuki Aerio
[email protected]
Old 02-10-2003, 05:01 PM
whtteg's Avatar
upgraded cam shaft?
short answer, it would change how the valves open and close, creating better flow through the head and cylinders.
Do you have vtec? It will definatly help if so. Check out this site crower
A cam gear on a sohc motor is going to be pretty much a waste of money. Reason: you cannot change the timming of the exhaust valves and the intake valves seperatly.
Old 02-10-2003, 06:54 PM
yes i have vtec , so i should get a cam shaft then a cam gear, right?
Rattltrunk
Cardomain
2007 Mazda Mazda3
2003 Suzuki Aerio
[email protected]
Old 02-10-2003, 09:07 PM
whtteg's Avatar
IMO a cam gear is a waste of money on a sohc motor. The cam shaft is a good idea though. The camshaft won't be hard to install if you have a slight clue as to what you are doing. Try this link quickhonda . Hope this helps
is A6 cam-gear & Z6 cam-gear the same?? QuikShifter '88 - '91 Civic | CRX | Wagon | Shuttlee 8 04-12-2004 06:19 PM
cam shaft and cam gears in b16a GENONCARL Engineering/ Technical 1 03-28-2003 11:36 AM
Cams or Cam Gears bcsintegra Engineering/ Technical 18 02-05-2003 08:54 AM
cams & cam gear installation $$$??? KEiTHo Integra 0 02-26-2002 07:22 PM
