Old 02-07-2003, 09:44 PM
4thgenlude 4thgenlude is offline
Send a message via AIM to 4thgenlude
h22 or h23?
i plan to get a 4th generation prelude soon, but im not sure whether to keep the h22 motor or go with a h23, what are the differences?
Old 02-07-2003, 11:37 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
the H22 is the vtec motor , the h23 is the non...is also more torquey
My other ride..... is YOUR MOM !!!!!!
Old 02-08-2003, 05:41 PM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
Keep the motor is all I'm going to say unless its a high mileage piece a garbage
Old 02-08-2003, 06:24 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
keep the h23 block and put the b18 head on it.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 02-08-2003, 08:16 PM
I think he was saying he already has the h22 and is asking whether to keep that or the h23. At least thats the way I read it. So out of curosity would you pick a h23 block with a b18c head over the h22a? Ha and I'm only a ticket behind you so watch out...:flash:
Old 02-09-2003, 01:13 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
i think he means putting a h22 head on a h23 block, which is just like a lsvtec, but alot more powerful. but i dont like head swaps. the h22a is a good motor anyways, just run like 10psi, and youll be making about 300hp
Old 02-09-2003, 02:15 PM
i plan to replace the internals with crower cams and je pistions alot with others, what would be the highest and safest psi to run?
Old 02-09-2003, 02:43 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Are you serious? Anyways u can't do it. ITs b series and u can't mate it with h series.
Old 02-09-2003, 02:49 PM
mellowboy's Avatar
I wouldn't do it that high. H22 sleeves SUCK! I would resleeve it first. H22 and h23 are not much different in torque specs. Its only like 2 lbs difference.
92-96 Si / Se H23A1 4G - BB2 2258 9.8 : 1 160 @
5800 rpm 156 lb/ft @4500 rpm USA
94-96 Vtec H22A1 4G - BB1 2156 10.0 : 1 190 @
6800 rpm 158 lb/ft @ 5500 rpm
not much difference. IF you have high mileage on it just rebuild it.
Old 02-09-2003, 05:29 PM
crxlvr's Avatar
whoops my bad im thinking b20 block
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 02-10-2003, 09:35 PM
F23A4Racer750IL F23A4Racer750IL is offline
H22A mos def.
Old 02-10-2003, 10:37 PM
hybridsol's Avatar
hybridsol hybridsol is offline
Send a message via AIM to hybridsol
do you already have a h22? An h22a, h22a1 or h22a2 are going to be the best bolt in swaps for a 4th gen prelude. Then again you could always do a h23 block with an h22 head as suggested (good turbo motor). Here's everything you would need for that conversion. VTEC head, complete: cams, gears, rockers, valve cover, VTEC timing belt- VTEC has more teeth on the belt than the Si does,VTEC water pump, VTEC auto hydraulic tensioner for timing belt, VTEC manual tensioner, VTEC head gasket,VTEC lower, most inner crankshaft pulley, (96 is different due to sensors) VTEC intake manifold, VTEC exhaust manifold, VTEC ECU/ECM, VTEC injectors - if you don't change these over, then once you plug in the ECU/ECM you will keep blowing the 'EAT ECU' fuse when you crank/start the car,VTEC spark plugs and wires, VTEC water pump pipe -black pipe that runs behind the head from the water pump to thermostat housing-. but if you already have an h22 I'd stick with that motor.
h23 swap 4th gen civic? 92lude91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 03-16-2009 11:43 AM
H22/H23 blocks gunnmen01 Prelude 20 04-09-2004 12:17 AM
Turbo kits for H22/H23 Jermonsta Prelude 11 10-10-2003 01:08 PM
h22/h23 turbocharging question... iceiso Forced Induction 16 07-16-2003 02:39 AM
H22/H23 block gunnmen01 '88 - '91 Civic | CRX | Wagon | Shuttlee 21 03-11-2003 06:08 AM
