Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 02-07-2003, 07:12 AM
zippeay zippeay is offline
Exclamation 1.8T swap into A4 Jetta
Hello I was wondering has anyone done or know of any info on how I can swap a 1.8T into my friends 97 jetta? I found a whole engine swap for $1000 dollars but I can't find any info on how to do it or if it can be done. I know anythings possible but sometimes it isn't worth it ya know, any help would really be appreciated
Old 02-07-2003, 10:05 AM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
it shouldn't really be that hard...
i know there's axles and what not that you need, but almost all vw engines bolt up to all vw trannys...
case in point...
overboost.com had an article about a guy that put a 1.8t into an older (mk2) golf... and used a mk3 jetta trans... so, it could feasibly bolt up to your tranny...
check with companies like www.rpi-equipped.com... they should have a tech line...
Old 02-07-2003, 11:25 AM
Deakins's Avatar
Deakins Deakins is offline
You have two options, get a AEB engine from a '98-'99 Passat or '97-'98 Audi A4. Or get a newer engine and use a Eurospec Sport ECU kit to eliminate DBW.
The engines will drop right in, but you need to use the 2.0rear motor mount.
The engine will bolt right up to a 2.0 02o tranny, but if you are planing more power, you should use a VR6 02a tranny. The 1.8t 02j tranny would fit with small modifications.
The ringing of the division bell, have stopped...
AF User Guidelines
Old 02-07-2003, 05:03 PM
Ok wow you just blew my mind, you'll have to forgive me but I don't know jack about VW. My friend has one and I really want to help him out. Basically will this engine mount up in the same place? Or is there engine mount kits that I can buy? Thanks for all the help
Old 02-07-2003, 05:04 PM
Deakins's Avatar
Yes it will.
AF User Guidelines
Old 02-07-2003, 11:37 PM
Hey thanks everyone for the advice, guess I'll get to turning wrenches, I'll let everyone know how everything turns out and I'll post some pics
Old 02-08-2003, 05:15 AM
Deakins's Avatar
What car did the engine come out of?
AF User Guidelines
Old 02-08-2003, 06:24 AM
The new body style Jetta or Passat I'm not really sure, I just looked at the engine but I'll find out, does it matter if its it Passat or Jetta? Do they have the same motor mounts?
Old 02-08-2003, 06:29 AM
Deakins's Avatar
Yes, same motor mounts, but early Passat's had non-dbw engines with better cylinder heads..
AF User Guidelines
Old 02-08-2003, 06:34 AM
What about the ECU does it just plug in? Let me rephrase my last question, do they have the same motor mounts as the 97 Jetta?
Old 02-08-2003, 06:49 AM
Deakins's Avatar
You have to use the 1.8t ecu.
Use the 1.8t motor mounts in front, and keep the 2.0 motor mount in the rear.
AF User Guidelines
Old 02-08-2003, 07:11 AM
Hey thanks a lot I really appreciate all your help, I'll post a pic when we're done. We've already done a lot of work to it we shaved all the door handles "Don't recommend it because I didn't know VW used a vaccum system for the door locks" but it can be done. He also has the whole strickly foreign body kit, we just need to get him so power. Thanks again
Old 02-08-2003, 07:14 AM
Deakins's Avatar
np, keep me up to date
AF User Guidelines
Old 02-09-2003, 01:50 AM
GTi-VR6_A3's Avatar
GTi-VR6_A3 GTi-VR6_A3 is offline
H4X0R T0 T3H M4X0R
Send a message via AIM to GTi-VR6_A3
damn deak you amaze me with your information. i think after i get about 3k im gunna offer my neighbor to buy his slc hopefully cash will tempt him.
-GTi-VR6_A3
-GTi-VR6_A3
Old 03-26-2003, 02:35 PM
Berticus Berticus is offline
I want to mod up my engine, but what I want to know is, money and power wise is it better swap my engine and get a 1.8T or should I stick with my 2.0l?
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
