Old 02-03-2003, 08:57 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
B16 questions....
ok, as some of you know, I got a b16 w/ LSD tranny, but since it's just chillin' in my garage right now, I figure I need to replace the essentials; timing belt, water pump, etc....my question is, what do I order parts for? Is there some specific model of car I can use, or am I gonna have to mix and match from all years of cars? Next question, since I got the LSD tranny, is there any special fluid I should be using? Next question, I want to get an aftermarket clutch, where's a good place to order from, and what car do I order the clutch for? Next question, I was thinkin' about throwing in CTR cams and maybe the intake manifold too, are there any good sites to pick up Type R stuff from?
Any help is appreciated.
Old 02-03-2003, 09:07 PM
GTA's Avatar
GTA GTA is offline
Whee..
i would think you could use parts for a Del Sol VTEC engine b16a3, or the 99-00 Civic Si b16a2, since they are both b16's also...i may be wrong though..i dont know that much about b-series
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
Anything related to just the motor can be sourced from the 95 Del Sol VTEC (obviously the B16A3 equipped model - not the d16z6 si...derrr). This will work for the timing belt, water pump and most everything else on the motor itself (besides the distributor - which you will need a non-OBD JDM B16A distributor and some misc. things on the intake manifold.)
I would recommend using GM syncromesh for your trans fluid. It hold just over 2 quarts (i think it's between 2.1 and 2.3 quarts). The stuff is like $17/quart but it is totally worth it.
You need to order a clutch for a 90-91 Integra. NOT the 92 or 93. The spline count is different on the clutch disk. I'm not sure of a good place to order the clutch from...but i would go for a Centerforce dual friction or a clutchmasters stage II or I.
As far as Type R stuff is concerned...www.jdmhondaparts.com sells that stuff. Ebay and thepartstrader.com also frequently have b16b cams....but im not sure about the intake manifold. If i was you, i'd get the Skunk2 intake manifold.
hope this helped
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
Old 02-04-2003, 12:01 AM
seth 90DX/ZC seth 90DX/ZC is offline
Banned
All of the B series motors are compatable... Hense ls/vtec. You can order all of the parts for the GSR and they will work (header with modification)... I would recomend using other cars with B16's in specific such as the 99 civic SI coupe or as 88CiViC_DX said a DEL SLOW will also work... Cam shafts will be the same and all that ish... But if you want aftermarket suport for the B16A(1?) Go to www.yahoo.com and type in "B16A Performance Parts" you will be drowned! Or if you have a frend who speeks japaniese (I do!) you can have him/her order parts for the SiR from japan which is essentialy what you will have after you swap the engine.
Old 02-04-2003, 09:47 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
i got most of my b16a parts from ebay without a hitch.
i ordered the CTR cams and pistons, and crower retainers, valves and BPM springs.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 02-04-2003, 05:07 PM
Marc-OS's Avatar
How much did all that stuff cost?
Old 02-04-2003, 05:16 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Ctr cams usually go for 500 new. Ctr pistons usually go for 310 with piston rings.
Old 02-05-2003, 10:57 AM
crxlvr's Avatar
i paid 500 with shipping for my cams, and 285 with shipping for the pistons with rings
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
B16 Question Here slammedcivicsi '88 - '91 Civic | CRX | Wagon | Shuttlee 6 06-07-2003 02:02 PM
b16 question Jetts '88 - '91 Civic | CRX | Wagon | Shuttlee 18 03-17-2003 01:56 PM
B16 Question - Please Help Asap Fishcat37 '88 - '91 Civic | CRX | Wagon | Shuttlee 3 07-03-2002 10:52 PM
b16 question outofstep '71-'87 Civic | CRX 2 03-28-2002 07:30 PM
b16 question!! mellowboy Engineering/ Technical 5 03-27-2002 03:30 PM
