Old 06-06-2003, 08:26 PM
slammedcivicsi's Avatar
slammedcivicsi slammedcivicsi is offline
B16 Question Here
If I buy a OBD0 JDM B16A.....and a UNCUT Wire Harness....and my motor includes the ECU tranny....will this just be "Plug and Play".....I need to know A.S.A.P. as I plan on buying these things providing they make the swap easier.
89 DX: LS Powered
88 CX: Project ZC
Old 06-07-2003, 01:24 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: B16 Question Here
No it will not be plug and play.
Old 06-07-2003, 01:51 AM
Re: Re: B16 Question Here
why is this ?....If its the engine, ECU, and Engine Harness and such....shouldnt it just snap in as-if I were to get a whole clip welded on ?
89 DX: LS Powered
88 CX: Project ZC
Old 06-07-2003, 01:58 AM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
Shift linkage and Motor mounts are what u will need......
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 06-07-2003, 07:05 AM
but in terms of wiring....Im all good..... I mean I can do he wiring....I just have better things to do that wire an engine for 2 hours.
89 DX: LS Powered
88 CX: Project ZC
Old 06-07-2003, 07:21 AM
jNYCe5 jNYCe5 is offline
Send a message via AIM to jNYCe5
If you have an Si, all you will need to do is use your EXISTING harness and the five wires for the vtec, oil pressure/ground, 2nd 02, and knock sensor and extend those wires into the ecu...
You cannot use the harness that comes with the motor. All you need from that harness are the connections for the pre-mentioned connections.
Let me know if you have any more questions
edit* noticed you have a DX. if you do not have the si engine harness, then you must first convert to MPFI, and then proceed as mentioned above
Julian
Old 06-07-2003, 02:02 PM
mellowboy's Avatar
Yeh like what jNYCe5 said. I took both my si harness and b16 harness and took it to my boy and he did the wiring. The only thing its good for is the connections.
D16 Si and B16 Vtec here! doug294 '88 - '91 Civic | CRX | Wagon | Shuttlee 8 01-24-2003 06:39 PM
B16 Question - Please Help Asap Fishcat37 '88 - '91 Civic | CRX | Wagon | Shuttlee 3 07-03-2002 10:52 PM
b16 question outofstep '71-'87 Civic | CRX 2 03-28-2002 07:30 PM
B16 is here! 1 problem... ricodemus Engineering/ Technical 3 03-27-2002 09:57 PM
b16 question!! mellowboy Engineering/ Technical 5 03-27-2002 03:30 PM
