Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-03-2003, 02:50 PM
alphalanos alphalanos is offline
Suspension
im looking to do some suspension upgrades on a future eclipse. similar to touring cars. all i need to do is lower the car, tighten the suspension, and reduce body roll. any suggestions on parts?
Old 02-03-2003, 05:24 PM
Spectrum Spectrum is offline
Send a message via ICQ to Spectrum Send a message via AIM to Spectrum
Eibach Sportlines, Tokico Illuminas, RM racing roll bars.
Old 02-03-2003, 06:20 PM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
agreed... nice setup... handles well..
if you've got a stock front bar, just get a back one, which will dial out the understeer...
upgrading both isn't bad, but if you can only afford one, get the rear...
Old 02-04-2003, 08:29 AM
turboawdgsx turboawdgsx is offline
If you can afford it, get a good set of coilovers, either DSS or Ground Control. Both are excellent & allow you to determine your spring rates for better handling. After those, you'll want to upgrade your stock shocks. I HIGHLY recommend Koni Yellows. Adjustable & extremely well known in racing circles. If those are out of your budget, pick up a set of KYB AGX's. Still adjustable, just not as many options as Koni's.
The RM sway bars are definitely the way to go. Good call guys.
With this setup you'll be able to adjust everything, ride height, stiffness of shocks, corner weights, everything your DSM needs.
Rob
"Got car lenghts?" or "You can turbo anything but can't make stupid people smart, something wrong with this picture?"
Old 02-04-2003, 08:31 AM
Fliquer Fliquer is offline
Send a message via AIM to Fliquer
I'd say koni yellow with H&R springs. I have tokicos and eibachs on my car (but its the prokit) and I find this setup to be softer than I expected.
Isitcontagious.com
'92 S13 coupe
KYB adjustable struts + Whiteline springs
Urethane bushings in all control arms and subframe
Cone Filter
Next up: LSD
RIP #05
Old 02-04-2003, 01:06 PM
sounds sweet thanks alot
Old 02-09-2003, 05:22 AM
GSXer GSXer is offline
If you want a good all around setup, B+G makes really good coil over system, yet JIC takes the cake.
