Old 01-27-2003, 10:22 AM
Vric's Avatar
Vric Vric is offline
Tamiya Color ?
Hi, simple question.. I have used some Tamiya Spray Can with no problem so far.. but I want to know if Bright color are easy to work with ? (ie: Yellow Orrage etc..) I used some Testor, model Master and even airbrushed some Bright color (mainly Yellow) and I always got 2 or 3 hours of sanding after
Does Tamiya Orage and Yellow Spray can are better ?
Thanks
Old 01-27-2003, 10:54 AM
Veyron's Avatar
Veyron Veyron is offline
Thumbs up
All Tamiya TS paints are very consistant in the way they spray and settle on the model. All are very smooth!
Old 01-27-2003, 11:17 AM
360spider's Avatar
I agree, all TS paint are great, very consistent, and very easy to apply if you follow the instructions.
Old 01-27-2003, 11:21 AM
Vric's Avatar
thanks.. Wanted to know before buying for 30$ of paint
Old 01-27-2003, 12:05 PM
360spider's Avatar
$30?
For how many cans?
They are $4.50 per can here in TX.
Even cheaper on eBay. I got 6 cans for $15.
Old 01-27-2003, 12:21 PM
freakray freakray is offline
AF Modelrater
Alex,
Vric is in Canada, so I think he is talking in Canadian $'s
I admit that it gets confusing.....too many different $'s to worry about.
Ray
AF User Guidelines
Old 01-27-2003, 12:42 PM
Bookshelf's Avatar
Bookshelf Bookshelf is offline
Oh, bright colors are very easy. I painted a Skyline lime green last summer, it turned out great.
Old 01-27-2003, 12:56 PM
Vric's Avatar
Originally posted by freakray
Alex,
Ray
Each can are 9$ Here.. 4.50$US seam great price (should be 7$Can) anyway.. will buy 3 or 4 can will cost me near 25$US
Old 01-27-2003, 02:31 PM
daggerlee's Avatar
My store charges $5.75 per can, so don't feel too bad.
If you follow the instructions (heat up can, shake for 2 minutes, mist coat first, white primer etc.) it should come out great.
Dan
Old 01-27-2003, 03:05 PM
Vric's Avatar
White Primer.. this is an other thing my Hobby Store dont have
Is it ok if I use Flat White color insted ?
Old 01-27-2003, 03:09 PM
daggerlee's Avatar
As long as it's lacquer based, it'll be ok. Also if the body is molded in white, you might be ableto get away without using primer. You must use white though since you are spraying yellow, which is semi translucent.
Dan
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
