Old 01-26-2003, 12:37 PM
454Casull 454Casull is offline
No such thing as forged steel engine blocks?
They have forged aluminum blocks, why not steel?
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 01-26-2003, 09:16 PM
911GT2 911GT2 is offline
Simply not worth the cost.
Steel's not significantly lighter than iron and its heat resistance properties aren't great either. Aluminum is much lighter.
Some people deserve to have their vocal chords ripped out. Oh yeah, and American beer is like having sex in a canoe...it's fucking close to water.
Proud member of www.automobileforum.com
Mod -www.autoworldforums.com
Old 01-26-2003, 11:35 PM
FYRHWK1 FYRHWK1 is offline
Send a message via AIM to FYRHWK1
barely lighter, steel expands more then cast iron when hot and that causes hell, if you're going to spend the money and hav heat expansion then aluminum is the only one worth it.
Ti blocks are much the same, but they have better heat properties then steel does and can be in between aluminum and iron, with more strength then both, but you're talking insane pricetags.
Old 01-27-2003, 12:03 AM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
ok i actually think that the iron bloks are not pure iron wich is hard to use in its native form . Its most likely an iron carbon alloy which is steel.
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 01-29-2003, 11:10 AM
SaabJohan SaabJohan is offline
Iron blocks are usually sandcast in a cast iron alloy. In this way there are no need for liners. In an aluminum block liners must be used, or the cylinderwalls must be coated with Nikasil or similar. Wet liners are prefered before dry liners, and this creates a problem between the steel liner and aluminum block since the aluminum expands more than the steel. The latest is however coated ultra thin AlMC liners in an AlMC block, these are however very expensive.
Cast iron is a very good block material, the only downside is the weight. BMW even used cast iron blocks in F1 during the eighties.
Old 02-03-2003, 01:26 PM
Jared_80 Jared_80 is offline
Banned
They do make steel blocks.
There are already steel blocks in production, but you have to buy a TVR speed 12 to get one.
99 Sunfire GT 2.4L Twin Cam Auto--CLICKING NOISES FROM ENGINE BLOCK E. Frank Cavalier Problem Diagnosis 8 07-28-2009 06:25 PM
Steel engine blocks?? Jared_80 General Discussion 9 12-18-2003 11:50 AM
Is there any such thing as an import scene in Kentucky?? 4GZChatch '88 - '91 Civic | CRX | Wagon | Shuttlee 11 02-18-2003 09:45 AM
Is there such thing as a 4 dr. 325IS E30? VWVancouver 3 Series 3 01-18-2002 10:51 AM
