Old 01-22-2003, 08:44 AM
bdstbtch's Avatar
bdstbtch bdstbtch is offline
Send a message via AIM to bdstbtch Send a message via Yahoo to bdstbtch
Engine Squeal
My engine is making a belt squealing noise only when I barely press on the gas pedal. If I press it more than half way, it stops. It only used to make this sound when it was wet. Yesterday morning I had to park by the sprinkler that soaks the cars cause the parking lot was full and I figured it was from that, but yesterday was a nice warm day and I drove it around, and it never stopped. This morning, it's still doing it. It also does it when I turn the car off. Whats wrong? Please help...
Thanks!
~ Cherylyn ~
Old 01-22-2003, 08:56 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
Sounds like an alternater belt squealing, next tiime it starts squealing like that, spray a little bit of wd-40 on the belt. If it stops for a bit then the belt is either to tight or needs replaced....
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 01-22-2003, 09:47 AM
darolh darolh is offline
gunnmen01
DO NOT SPRAY WD 40 ON THE BELT!!!!!!
It sounds like your belt however. It either needs tightening or replacing. If it's been in there a while you'd might as well replace it since you'll have it loose.
Old 01-22-2003, 02:57 PM
wikedcrx wikedcrx is offline
It happened to me to, I even replaced the belt too but it didnt go away. I then found out that the bolt that holds the alternator fell off. Which made the alternator move at an angle rubbing on the belt. So check the bolt that holds it not the one you adjust. You can only see it by looking under the car, its about four inches long you cant miss it. Ohh yeah dont put WD 40 on it, it just makes it worse. hope this helps
>>>>>Sam
Old 01-22-2003, 03:22 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
I'm goin through it rite now. This is my second belt that i have to replace. It always squeaks after i drive in the rain...
Just replace it.
Old 01-22-2003, 03:42 PM
gunnmen01's Avatar
spraying a little bit of wd 40 on a belt isnt going to hurt it, but it will tell you if its the belt thats squeaking...
gunnmen01
Old 01-22-2003, 04:40 PM
bdstbtch's Avatar
Fixed!
Hey, thanks you guys for all your help...but my dad and I went out there just now and it was a vacuum leak off the manifold. I guess one to the nubby plastic things came off, and we put it back...now all fixed!!! Weird noise for a vaccuum leak... oh well...
Thanks again! I appreciate it.
~ Cherylyn ~
Old 01-22-2003, 06:10 PM
gunnmen01's Avatar
Well i'm glad you got your car fixed either way....
gunnmen01
Old 01-22-2003, 08:27 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
this happens to me at HIGH RPM's whenm my AC is on!
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 01-22-2003, 08:36 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
My car has been doing the same thing. From like 800-2500 rpms it makes that annoying sound, not all the time but a lot. You got pictures of what you did to fix it since I don't know much about vacuum.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
engine squeal kristi02 Taurus | Taurus Wagon 3 05-23-2005 06:56 PM
1998 Engine Squealing jlistunner Taurus | Taurus Wagon 4 11-09-2004 05:39 PM
Engine SQUEALS! adamiecjr1 Caravan | Voyager 1 07-29-2004 06:00 PM
Engine squeal GeoMetron Metro 9 07-04-2004 03:27 PM
