Go Back   Automotive Forums Car Chat > Hummer (AM General) > General Discussion
Old 12-29-2002, 03:28 PM
jan christensen jan christensen is offline
Wiring Help Needed
I HAVE A 94 HUMMER WAGON THAT DOES NOT CHANGE OUT OF FIRST GEAR. I KNOW IT IS AN ELECTRICAL PROBLEM RELATED WITH THE TRANSMISSION CONTROL MODULE. DOES ANYONE KNOW WHERE I CNA GET WIRING DIAGRAMS ON THIS RELATED ISSUE OR HAVE ANY IDEAS WHAT THE PROBLEM MIGHT BE. THE SPEEDO DOES NOT WORK EITHER. THANKS.....JAN.
Old 01-11-2007, 07:13 PM
USMILRET USMILRET is offline
Re: Wiring Help Needed
You should have a 1/2 shift solenoid that either isn't getting signal up to it, doesn't work or the spool valve doesn't work. That's just for first gear. If all of the other gears work fine then the pressure control valve works fine.
PM me.
Old 11-06-2008, 06:17 PM
GenBiltstein GenBiltstein is offline
If you have the 4L80-E transmission and if you have a transmission problem. You have a stuck checkball at the 1-2 shifting solenoid or the shifting valve is sticking and not returning.
I will describe the operation to you.
The computer controls the first gear in this manner.
By controlling the ground switch in the computer. when the puter decides enough is enough and lets go to second then it opens that switch and denying power to the 1-2 shifting solenoid. When that happens the pressure bleeds off and the valve relaxes and into second gear you go.
Provided the ECU is reading everything correctly like engine load and rpm.
Old 02-08-2010, 10:36 PM
alpinto088 alpinto088 is offline
which type of help you needed..??
albert
used caravans
Old 03-24-2010, 12:51 AM
david357 david357 is offline
Do you want a wiring diagram to fix the problem yourself or some suggestion on how to fix it. Its not clear
Old 03-24-2010, 06:11 AM
Most likely it is not the wiring. It could be soleniod related.
Disconnect the passthough connector at the transmission. At the transmission side there are pins E and A. test those for resistance. I believe the resistance should fall into 14 ohms. Definitely not over 20 ohms.
You can check for continuity as well.
If all seems to check out well then drop the pan.
Get two nine volt batteries. Soldier them in series with two leads. Test the two leads right on the solenoid. You should hear a clicking sound.
You can also conduct the very same test at the passthrough connector. If you hear the clicking sound then you are good.
Check all grounds with a multimeter. .1 ohms from terminal to ground. Everywhere you go to check a ground. If it is higher then remove that ground and clean it. Recheck. Battery ground. Block. Battery to chassis. I mean everywhere.
If in the event that everything is checking out then remove the soleniod. There is a pressure checking procedure that is not done so much nowadays. Replace it. A 3/8s star socket and a ratchet are the tools.
You might have a hanging valve that doesn't want to move after actuation of the 1-2 solenoid. That will be verified after replacement of the solenoid.
Need Spark Plugs and Wire help need. 02DenaliXL Yukon 3 06-22-2009 07:00 AM
Air Suspension Wiring Help Needed nitrus rush Problem Diagnosis 5 08-28-2008 07:34 AM
Pop Up Camper Wiring Help Needed WillScarletMacaw M Bodies 6 10-25-2004 10:15 PM
Trailer wiring help needed please Indyrider M Bodies 4 09-21-2004 06:18 PM
HX wiring... help needed 4GZChatch '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 06-15-2004 08:42 AM
