Old 12-27-2002, 08:31 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Motor Parts Interchange
i got my B16A1 the other day, and i wanted to replace some parts while the engine is out and easy to work on before i put it in. Will parts from the 2000 SI and/or the 1994 Del Sol Vtec engines bolt directly to the engine, or do i need to get A1 parts?
if possible does anyone have a list of the interchanges?
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 12-27-2002, 09:09 AM
91zc 91zc is offline
Timing Belt, Water Pump, Thermostat, Valve Cover gasket and spark plug tube seals, Oil pan gasket, intake manifold gasket, spark plugs
You can get these from either the 94+ Del Sol DOHC VTEC or the 99 Si.
Distributor cap and rotor, Alternator pulley and belt, lower radiator hose, You can also buy another lower radiator hose and cut it to fit for the upper radiator hose.--90-91 Integra
Exhaust Manifold gasket, Head Gasket, Crank Pulley: any VTEC b series
This is all I can think of for right now. If you need anything else let me know..
91 civic 4dr
b16a
14.8@94
Old 12-30-2002, 11:39 AM
crxlvr's Avatar
thanks man, if anyone else can add to this please do, i wanna replace everything.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Taurus Interchangable parts rlhoward59 Taurus | Taurus Wagon 3 11-17-2010 11:19 PM
91-92 cavalier parts interchange funiwant Cavalier 0 03-12-2010 05:39 PM
are h22 parts interchangable with h23 parts preludacris88 Prelude 6 10-23-2005 03:03 PM
Dogbone motor mount interchangability? Mike Gerber Camry/Camry Hybrid/Vista 3 09-25-2004 12:33 PM
86 88 735i parts interchange clu404 7 Series 0 11-13-2002 02:01 PM
