Old 12-03-2007, 09:05 AM
Blister1 Blister1 is offline
96 van
I hope someone can help me figure out how to repair the heater blower on my 96 dodge van. It only works on high speed. How can I repair this? Where would the resistor be located?
ALSO
As soon as we turn the van on the airbag light comes on and stays on til we shut the motor off. The van has 95,000 miles on it. Is it possible that the airbag is no longer any good? How can I disconnect this light?
Thanks
Old 12-03-2007, 11:53 AM
dugan50's Avatar
dugan50 dugan50 is offline
Authorized Vendor
Re: 96 van
Two things.
The heater problem is most likely the heater fan resistor that has rusted and broken. Depending on what van you have it is either under the hood or under the dash. Repost more info (year, make, model & engine) & I can get more specific.
The airbag may also be a number of things. The most popular item for Chrysler is the clockspring failure in the steering column, but I would suggest a scan to identify this problem. It can get real expensive throwing airbag parts at a car.
In the meantime, here is some more information about the clockspring
The clockspring is a ribbon wire that is coiled up inside the steering column. It delivers current to all of the systems mentioned above, airbag, cruise control and horn. When it fails (and they do a lot) the wire breaks leaving the circuit open and inoperative. This will cause the airbag light to come on and shut down the system. As long as that light is on, the airbags will NOT deploy, even in an accident.
This was a factory recall and many customers are unaware of that. Her is that link
Clockspring Recall
Contact your local dealer and they will accommodate the replacement for you.
Check out these web pages for a more complete description:
http://www.airbagsolutions.com/docs/Clockspring.pdf
I hope this was helpful to you. My information comes from years of experience in these businesses.
http://www.airbagsolutions.com http://www.stolenandrecovered.com
Airbag Service, Airbag Replacement, Airbag Diagnostics
Thank You,
Douglas Gan
Old 12-03-2007, 01:25 PM
96junkercaravan 96junkercaravan is offline
Re: 96 van
I Also had the same problem with my 96 Grand Caravan. A $15 resistor coil did the trick just as Dugan 50 explained in his previous post.
Old 12-09-2007, 09:58 PM
HeadlessHorseman1 HeadlessHorseman1 is offline
Re: 96 van
Just about everything you need to know about your blower motor, resistor block and relay...
http://www.automotiveforums.com/vbul...d.php?t=340871
