Is The interior above head light supposed to come on when u open your door, or is mine just f*cked up?
mine has a switch so you can make it come on when the door opens or not, if yours has the switch it could be just the switch is bad
yeh mine has a switch, and ive tied it in evry direction. It only comes on when i flick it. So it must cause sumpins screwd. thnx
LOL..i got a good mental picture their...open car door, sit down...WHACK.... let there be light
haha, yeh, thats pretty much it. it kinda sux getting into a car where u cant see sh*t
yeah it definetly sucks not having interior light
ok i have the same problem and i found out what it was....on the place where the door closes on the car not the door thier is this little black spring loaded thing and mine broke and now my light doesnt work when i oopen the door thats what it is in my case
take the bulb out and clean the contacts...........that might help or take the door pin out and check that connection, its easy
********** My 94 SS ********** 90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car |
how do you make the light brighter
AF Teen Crew![]() Purehonda.com - may she rest in peace 1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp DJM 4/6 drop kit being sold Full Throttle 9.5 inch lift being installed 1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton ![]() corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header Make an Offer [email protected] |
get a different bulb
blah |
mine doesnt work either. it really pisses me off cuz i cant see anything at night. It turns on when i put it to the on position but doesnt turn on when i open the door. So, its definitly not the bulb, ill have to pole around with the black springy door sensor thing tomorrow. Ill tell you if i find anything...
OK, i found the problem, The latch thing is getting kinda rusty where the connecter grounds out to turn the light on, so all i did was scrape away the rust and slapped sum wd-40 or sumpin, and bent the tracks that the latch slid along, and now it works great! I had to do this to both driver and passenger sides. And yes im sure that the CX and STD are the exact same thing. Cause mine is just that, STD. no options on it.
front light
Where can I find Headlights for my 4th Gen Civic Hatch?
Re: front light
also put a post in our classified thread ![]() http://www.automotiveforums.com/vbulletin/t71240.html
AF Bay Area Crew ![]() RIP Melt 2008 Mitsubishi Lancer Evolution GSR 2007 Toyota Prius ![]() ![]() I <3 and miss my 4g
yea, i did the exact same thing that fiercecivic did today too. It works perfect now. just use a file or my dremel tool worked great to get all the rusy off of the metal connectors. then lube it up and make sure that the track is tight enough to keep it moving straight, so its not wobbly and loose. plug it back in and screw it back on and it should work. And like fiercecivic said, you gotta make sure you do both doors.
