Old 10-01-2010, 10:18 PM
hot dome light man hot dome light man is offline
Lightbulb VERY Hot Dome Light
So, we have a 1994 Grand Prix. The dome light hasn't worked in a few years now, so I decided to check it out. It turns out the bulb does light up and work. There is no break in the filament or whatever. However, it gets VERY hot. By VERY hot, I mean within only a few seconds, it is too hot to touch with your hands, and could easily melt wax and weak plastics.
I have taken out the dome light bulb for now, so the bulb itself doesn't get burnt out, and more importantly not to cause a fire. I tried a Google search and Youtube search for hot dome lights, but not much info for this specific issue. I saw a post somewhere on another forum, where someone mentioned a short circuit, but it was very vague. What should I do? I know it's incandescent, but should it get -that- hot -that- fast? (I've heard about LED lights, but would rather just get this working, if I can.)
Old 10-01-2010, 10:54 PM
DrRadar DrRadar is offline
Just a guy
Re: VERY Hot Dome Light
I would check the voltage in the dome and the bulb resistance, then try to find out what the bulb resistance should be. Assuming the voltage is correct, a resistance that's too large might indicate a weakened filament with a hot spot.
Or buy a new bulb and compare the resistances...or just stick the new bulb in the dome and see if it works.
Oh, and make sure it's the right bulb...
Lloyd
18 Charger ScatPack 392
18 Lincoln Navigator L (Hers)
98 Grand Prix GTP Sedan (RIP)
99 Grand Prix GTP Coupe (to the moon)
05 Wrangler Unlimited (Junior's)
03 Explorer XLT (Sissy's)
Old 10-01-2010, 11:21 PM
danielsatur danielsatur is offline
Go green, and mount a Solar garden light on your dash, or go with a
less watts bulb.
Old 10-02-2010, 01:33 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
I agree with the top two, check to make sure the bulb you have is the correct part number and wattage for you specific car. If so, you can step down in wattage.
And as you mentioned switch to LED, they stay cool to the touch after hours of continuous use.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 10-02-2010, 01:57 AM
3100 3100 is offline
Banned
do some math and install several LEDs instead.
Old 10-02-2010, 11:11 AM
P
E X I
E
I X R
P= watts
E = voltage
R= resistance
I = current
I really like the idea of using LED's to save power, they do make LED Bulbs for the tail lights.
Do a google ''Universal LED dome lights''
2003 Venture Interior Lights OnThePike Venture 16 12-03-2010 12:39 PM
2002 Express dome light issue jtram2 Express | G Van 2 07-23-2010 07:57 AM
radio acc wire and hot wire makes dome lights work again hum TimWestTx Cherokee 3 09-28-2004 08:23 PM
dome light-after mali is turned off does the light goes on? capricex Malibu 2 06-21-2004 07:08 PM
1988LE Caravan dome light/left map light snipepod Caravan | Voyager 0 10-27-2003 11:20 AM
Tags
dome , interior , light , overheats
