Old 10-08-2007, 10:46 PM
tigeraid's Avatar
tigeraid tigeraid is offline
Authorized Vendor
Help me make these, um... "headlights."
Which I guess are actually just aftermarket driving lights. Ugh.
Any ideas? Not even sure where to start... The housing is easy enough, just some round styrene stock. But what about the lense?
Old 10-08-2007, 10:54 PM
klutz_100's Avatar
Re: Help me make these, um... "headlights."
take a look at this.
It's in Polish but I am sure you will get the drift and it might give you some ideas. HTH
PS Be a little patient waiting for the page to load.
Old 10-09-2007, 01:22 AM
bri g bri g is offline
Hi tigeraid, if you have some FD RX-7 models laying around, check out the oval foglights that you get from that. it should be perfect for your project
tamiya Rx-7 foglights:
Old 10-09-2007, 02:20 AM
kaho's Avatar
kaho kaho is offline
How about smoothing out the ends of some clear styrene rods from your clear parts trees? Cut a section out, put it into a drill, spin it while putting a file on its side to file out the right diameter. round out the end with sandpaper while still spinning. Buff to shine.
Old 10-09-2007, 04:09 AM
sjelic's Avatar
sjelic sjelic is offline
One word, Sakatsu
http://www.mediamixhobby.com.sg/cata...roducts_id=526
My effort
Sasa Jelic
SCALEMAKERS
Old 10-09-2007, 04:59 AM
cyberkid's Avatar
cyberkid cyberkid is offline
I'm not sure how tall the drops go, but you could try transculent blue mixed in with 'krystal klear' and drop it on wax paper. I've seen it done for gauge covers, not sure wether it would work for light covers.
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
Old 10-09-2007, 06:20 AM
quadzero's Avatar
quadzero quadzero is offline
This is the method I use but instead of a drill I just use my dremel. It's an excellent way to make signal and taillights too.
Old 10-09-2007, 07:28 AM
tigeraid's Avatar
Authorized Vendor
ah, that's a neat idea...
Old 10-09-2007, 09:02 AM
rallymaster's Avatar
Hello Tigeraid,
look at reference PC4.5 on this page:
http://www.renaissance-models.com/ma...d=37&Itemid=37
this one or maybe a smaller diameter one should help. It's the best way to make lens, because this is lens !
Phil
Old 10-09-2007, 07:54 PM
rsxse240 rsxse240 is offline
Hey John, I saw on here some time ago where someone took some aluminum tubing and stuffed some red plastic into it, then heated it up which soften/melted the clear red and made it stick to the tubing. then they hung it so it formed a "drip" or convex surface out of the end of the tubing. I am thinking that if you were to use some tubing and kind of smash it down to your "cat eye" shape of the fog lams, then use this method, you might have a fighting chance.
Old 10-10-2007, 01:14 AM
AudiS6Avant AudiS6Avant is offline
MV lenses by M.V. Products. used on model trains but are perfect for this. Many different sizes. PO Box 6622, Orange, CA 92863-6622 USA or order from http://www.discountmodels.com/
Old 10-10-2007, 06:40 AM
rod_k2's Avatar
rod_k2 rod_k2 is offline
Send a message via MSN to rod_k2
http://www.automotiveforums.com/vbul...d.php?t=706467
I believe this could help...
"Oh noez,it has more stickers than me! And a wing too!
Old 10-10-2007, 02:39 PM
Didymus Didymus is offline
What about 1/43 scale headlights? They come in all sizes and have a similar gleam, but I honestly don't know where to get them, except from a 1:43 diecast model or kit. You could Google "1:43 parts," or buy a cheap 1:43 model on eBay.
Diddy
