Old 09-28-2007, 07:41 PM
speedphreak speedphreak is offline
i screwed up....again!
So, I was painting the centers of my Castrol Supras rims white. I am using enamel and they look like complete crap! How can i strip the paint off and retain the shinyness of the rims? Thanks!
-Chris
Old 09-28-2007, 08:20 PM
Re: i screwed up....again!
nobody?
Old 09-28-2007, 08:30 PM
freakray freakray is offline
AF Modelrater
Originally Posted by speedphreak
nobody?
This isn't a chat room, you can't wait 39 minutes and expect a clear and concise answer.
Now, if the rim has chrome plating on it. You'll have to strip everything and then start over in which case you could saved yourself the wait and read this thread in the FAQ:
http://www.automotiveforums.com/vbul...007#post579007
BTW, to replace the chrome plating you will want something like Alclad.
AF User Guidelines
Lownslow's Avatar
Lownslow Lownslow is offline
enamel you say use mineral spirits but dont over do it
Old 09-28-2007, 09:31 PM
924_CarreraGTS's Avatar
924_CarreraGTS 924_CarreraGTS is offline
Mineral spirits will be a pain in the butt and probably won't take the chrome off (not without a lot of picking and scraping). Use oven cleaner. Let it sit for an hour and the plating should lift right off, taking the paint with it. If not, let them sit for longer (like a week) and the paint is guaranteed to come off. And why do they look "like complete crap"?
Alex
Old 09-28-2007, 10:56 PM
Well, after letting the paint set..they don't look too terribly bad. haha. I'm gonna put another thin coat on tonorrow, then detail and decal them. Wish me luck!
Old 09-29-2007, 01:18 AM
kaho's Avatar
kaho kaho is offline
Might have been mentioned elsewhere but anybody know will brake fluid strip chrome plating off plastics?
Old 09-29-2007, 04:16 AM
Yes, but some members of this forum are strongly against this, because there are other, much safer products out there that work just as well.
Old 09-29-2007, 06:40 PM
rsxse240 rsxse240 is offline
Isopropyl alcohol. strips everything, FAST.
well in most cases, anyway.
I'd guess that you sprayed white directly on chrome? if so, then you probably got a bunch of fish eye looking blemishes? it's because the paint won't stick to the chrome. the trick to painting chrome is lots of VERY THIN coats letting them dry for at least 10-20 minutes between coats.
