Old 11-25-2002, 03:21 PM
mmmese mmmese is offline
Need new engine.. What should I get..?
After suspecting that the problem was due to the distributor,
my mechanic told me the bad news...: My engine is dead.. (only 1 4th of it.. one cylinder is not working..)
He recommend me to put a used (45-5oK miles) engine there.
I have 1.5 dead engine on my car, and he said he can put 1.6l engine as well for 500 engine+ 400 labor.
Whar are your thoughts on it..?
Someone pointed out that there are different 1.6 engines..
What are the differences between B16a1, D16a6 and D16z6...?
Where can I get specs..?
For each of them, do I need to change the ECu tyranny and harness as well?
Where can I get these parts for cheap?
Txs a lot in advance..
Old 11-25-2002, 04:48 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
I can't tell you the that much on this, but here is a link with some swap info on it.
http://hybrid2.honda-perf.org/tech/4gtech.html
should tell you what all you need
hope it helps
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 11-25-2002, 05:58 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
that sounds about right rates for that replacement. however, i need to point out....the 1.6 won't be any faster than 1.5 unless they do the MPFI conversion.
another link to check out....
http://www.4thgenerationcivic.com/engines/Engines.htm
MPFI conversion is going from a dual port injection to mulit-port.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 11-25-2002, 07:06 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
you might wanna consider the ZC, it will bolt up to your transmission, however if you have dualpoint fuel injection you will need to do a Multi point fuel inection modification.
you can get a ZC for like 500$ it's 130-140hp, DOHC
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 11-25-2002, 07:09 PM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
you might as well go witht he d16z6 just because it can easily be found and you can readily get parts for it from a dealer and it has a massive mod basis for a d-series engine
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 11-25-2002, 08:06 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
i personally think that you should just do the mpfi swap and then put in a y8 or a z6 because its more economical.............. but if you really want power, just go b series......
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 11-26-2002, 02:37 PM
Dweezil6969 Dweezil6969 is offline
go all the way if you can afford it and get a b series!
`91 CRX DX Kind of moves
`90 CRX Si
Can also be found on:
XceedSpeed.com, MichiganCivics.com, and Zilvia.net
Old 11-26-2002, 04:02 PM
QuickSilverEF9 QuickSilverEF9 is offline
Send a message via AIM to QuickSilverEF9
I am going b18a then slowly building into an LS_VTEC (hehe) but if i get too impatient and have the lack of funds i will go d16z6 turbo. I would suggest u go d16z6 or d16y8 (both US spec sohc vtec motors) the swap is cheap and easy. Plenty of after market support and u can still change your oil with $20.
1997 Golf GTI VR6
-Leather Interior
-47000 miles
-JVC KDSH707 Head Unit
ON THE WAY
-2xInfinity Kappa Perfect 6.1 components
-12" Polk Momo sub
-JBL 600.1 amp
Future
-Brock B2 deep dish wheels
-Suspension.....
1993 Cavalier Needs new engine...but what one?! Cacophobia Cavalier 2 11-26-2004 03:34 PM
Might need new engine. Whats the diffs? aarcuda Park Avenue 24 09-20-2004 08:05 PM
need quick answer...what should be my nexy mod? whiteracer Forced Induction 32 06-01-2003 04:39 PM
I need a new car...what should it be? deftonez24 Cars in General 8 10-02-2001 12:16 PM
New car....what should i do first? slickkedar Engine 10 07-18-2001 04:03 PM
