Old 11-23-2002, 12:55 PM
mdnnccivicrcr mdnnccivicrcr is offline
B16b?
I was looking through Nippon's online price list for their engines and I noticed they sell a B16B "Type-R" engine what's the difference that and a B16A and would they swap in the same way? Also would this give me a reason to put a big "Type-R" sticker on the back of my car :hehehe: j/k dont answer that part ROFL
90 Civic EX *RIP*
90 CRX DX *RIP*
88 Civic DX Sedan (pushing boost) *RIP*
95 Accord LX Sedan
Old 11-23-2002, 01:11 PM
SiZ's Avatar
SiZ SiZ is offline
The difference between the B16B and the B16A is a couple thousand dollars. And the B16B makes 25 more HP.
Personally, I don't think its worth it.. Especially since you can pick up older B16As with the cable tranny (especially good if you get one with an LSD) and non-OBD ECU (all better to swap into a 4th gen) for a lot cheaper than even a newer B16A, let alone a B16B, wich if you ask me, has a jacked up price because so many people gotta have the "Type-R".
If I could get it for a good price I probably would pick one up, but I wouldn't spend much more than a GSR, and I wouldn't be putting it into a 4th gen. If you ask me, the absolute best B series motor you can put in a 4th gen is a 1st gen B16A. It makes good horsepower, and its cheap. Its a lot cheaper than most any other B series motor/tranny/ECU and the possiblities for upgrades for it are endless.
The problem, and the beauty of the B16B is that its built so well from the factory. It comes with an LSD. It comes with high compression pistons and good cams that make power really high. It comes with a bigger intake manifold. And it should come with a factory header.. Not a heavy cast exhaust manifold like most others. Its a nice motor, but if you want to tune it and don't buy top quality parts for it you're likley going to see a decline in HP rather than gains..
Just what I think.
To your last question: If you got the B16B and put a Type-R sticker on the back (or anywhere) of your car, that would tell me that you're wanting to do a swap for all the wrong reasons.
"The nympho of info, I'm fuckin' what ya heard"
Old 11-23-2002, 01:21 PM
thanks for the info, as for the last part of my question I was just jokin around
Also I've got a stupid question... what is a LSD? I probably know exactly what it is but I'm used to long-names...
90 Civic EX *RIP*
90 CRX DX *RIP*
95 Accord LX Sedan
Old 11-23-2002, 01:38 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
a lsd is a limited slip differential. basically its when one wheel starts to lose traction, it locks the other wheel in so power goes to that wheel too and not just to the one thats spinning.
so if you burnout, most of the time only one wheel spins, but with the lsd both wheels will spin. its more of an autocross thing or a drag racing thing
Old 11-23-2002, 02:14 PM
ya see, I figured it was something I knew. I'm familiar with a limited slip diff from my dumb-estic days...
I'm surprised I didn't figure that one out though, I guess I've been calling it a limited slip rear-end for too long :toothless
90 Civic EX *RIP*
90 CRX DX *RIP*
95 Accord LX Sedan
Old 11-23-2002, 03:09 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
B16b comes from a civic type r. Its 185 hp and its much higher compression. It is expensive and i don't think its worth it either. I'd rather use there engine components like there cams and valvetrain. All b16b's comes with lsd equipped already.
what's better for swap B16b, B18c1, B18c5 liquid8 Engineering/ Technical 8 02-13-2002 01:13 AM
B16B (96-00 Civic-R ) Engine SUPERCHARGER vs. TURBO 2800.2CVC Forced Induction 5 01-18-2002 06:30 PM
b16b block or get the b20z b16b bomber '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 01-09-2002 09:09 PM
Converting B16B to 1.8 b16b bomber '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 6 12-03-2001 01:25 AM
b16b engine b16b bomber '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 8 11-19-2001 11:05 PM
