Old 11-18-2002, 11:58 AM
stalegreenpunk stalegreenpunk is offline
Send a message via AIM to stalegreenpunk Send a message via Yahoo to stalegreenpunk
Clutch slipping?
For a month or so now my clutch has been slipping when I release the clutch (well when I do so, my car shakes pretty bad). It doesn't do it so bad in higher gears, or after it's been warmed up. I'm not sure if there is oil on my clutch or what. I was wondering if anyone knew of any ways i could check to find the exact problem without ripping my engine or tranny apart to do so.
Old 11-18-2002, 12:17 PM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
Is the clutch engaging really high up? If it is, try adjusting your clutch cable. I believe that you rotate the plastic knob by the shift fork clockwise (not completely sure tho- it's been a while ).
As far as checking to see if you have oil on your clutch disk, the only way that you will know for sure (unfortunately) Would be to remove your trans, and then remove the pressure plate to expose the disk. hope this helped a little
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
Old 11-18-2002, 02:52 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
clutch
What your describing is called clutch chatter. Does the clutch grab if you were to drop it at like 3k ? Does it just chatter or slip or both ? Chatter is usually caused by the flywheel having heat spots on it, or it's possible your pressure plate is goin to shit.
Old 11-18-2002, 03:02 PM
The clutch grabs fairly well if i dump it at 3k, slips a little if i'm pulling out on a hill, chatters most other times.
Old 11-18-2002, 06:46 PM
Clutch
Than i wouldn't worry too much about it. Unless it slips bad. Chatter is a some what common things for a clutch to do. Some new ones do it if the flywheel isn't machined correctly when a new clutch is put in. I guess just go with it, but you might want to think about putting a new clutch in, in a few months or whenever yours gets too bad.
Old 11-19-2002, 03:36 PM
turbcivic's Avatar
turbcivic turbcivic is offline
Re: Clutch slipping?
Liar. Easites way is go under the car and look up were the trans mounts to the engine. Remove the bracket between the two and you will the see the trans cover. Remove the four bolts and pull off the cover. If you feel oil in there, it is probaly a rear main seal.
00 Eclipse GT (115k mi) Clutch Question Stock00ClipseGT Eclipse 2000+ 3 11-26-2010 02:39 PM
944 clutch slips "no play in pedal" heybuddy 924/944/968 1 04-12-2004 12:54 AM
Is this clutch slipping? tomxz Engineering/ Technical 2 07-13-2003 11:45 AM
Clutch slipping on 1995 Jetta GruvMSTR206 '91 - '96 1 03-24-2003 04:39 PM
why is my ACT HDSS clutch slipping? neunan Engineering/ Technical 0 12-29-2002 01:13 AM
