Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 04-10-2004, 11:26 PM
heybuddy heybuddy is offline
Question 944 clutch slips "no play in pedal"
I have a slippage problem. There is no play in the clutch pedal.
The clutch wont slip until the car gets warmed up good.
then when it slips...If I pull up on the clutch pedal the slipping STOPS!
Is there some sort of adjustment that can be made? to allow the clutch to engage all the way?
[email protected]
Old 04-12-2004, 12:54 AM
83-944 83-944 is offline
Re: 944 clutch slips "no play in pedal"
Can you pull out the clutch pedal more than 1/4 inches? If so, then you need to grawl under the steering wheel and follothe pedal arm to a return spring mechanism at the top of the arm. Just replace it. It's a pain to try to rebuild it if broken.
If the pedal is all the way out then crawl under the steering wheel, there's a long threaded shaft w/ jam nuts connecting the clutch pedal arm to the master cylinder. You'll figure out what to do when you get there.
83 - Porsche 944 - daily driver
62 - VW Karmann Ghia - never ending restoration project
95 - Ford Mustang - wifes
00 Eclipse GT (115k mi) Clutch Question Stock00ClipseGT Eclipse 2000+ 3 11-26-2010 02:39 PM
'86 944 clutch pedal is on the floor ropDave 924/944/968 8 05-19-2004 05:29 PM
944S clutch mystery Kevduck 924/944/968 2 08-22-2003 07:02 PM
944 Clutch Problem? GregJ 924/944/968 0 09-10-2002 10:24 PM
83' 944 clutch swap chriscampbell 924/944/968 0 06-22-2002 08:19 AM
