Old 07-12-2003, 04:42 PM
tomxz tomxz is offline
Question Is this clutch slipping?
Dear people,
I own a 1997 Renault megane. Since recently I have a problem where in if I push on the accelerator pedal while in the 4th gear, the car jerks for a moment (or two) and then starts to accelerate as normal (these are mostly cirumstances where I should have switched to a lower gear, but didn't). Off late, I see the problem more frequently. Is this what is called as "Clutch slipping"? Or what else could it be ?. Can somebody tell me?
Old 07-13-2003, 09:28 AM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
Most cars will do that if you have them in too high a gear for you speed. It's just drivetrain vibration. You should avoid it by using lower gears when you're going slower. The biggest potential for damage is probably to your journal bearings, which are seeing low-speed, high-load conditions in the situation you describe.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 07-13-2003, 11:45 AM
killasoundz killasoundz is offline
clutch slipping would be when your in 4th gear and you go to floor it and your engine revs but you dont accelerate right away there will be a pause then youll hear the engine die back down and youll accelerate
1979 celica GT 5speed
ww.classic-celica.com
00 Eclipse GT (115k mi) Clutch Question Stock00ClipseGT Eclipse 2000+ 3 11-26-2010 02:39 PM
Do you think this is a clutch slipping? Gateway 3000GT/Stealth 11 12-01-2004 10:36 PM
Clutch slipping on 1995 Jetta GruvMSTR206 '91 - '96 1 03-24-2003 04:39 PM
why is my ACT HDSS clutch slipping? neunan Engineering/ Technical 0 12-29-2002 01:13 AM
Clutch slipping? stalegreenpunk '88 - '91 Civic | CRX | Wagon | Shuttlee 5 11-19-2002 03:36 PM
