remote programming for Pathfinder
anyone have the procedure for programming the keyless entry remote for a 2002 Pathfinder???please...
yeah i can find out for you if you are sill trying to find out if you are just reply to this post and i will ask a tech at work it is easy just is a lot of typing so if you found it already there is no need for me to type it
Robert
A: Every manufacturer has different means of programming for a replacement remote. The Nissan dealer has a choice of using a computer scan tool known as the Consult-II or the conventional method that you can do yourself. It's not too tough as long as you're using the correct remote. Get in the vehicle. Close and lock all doors utilizing the driver's power-door lock/unlock switch. Insert and remove the ignition key more than six times within a 10-second period (at a rate of one insertion/removal cycle per second). Don't rush the process, and be sure the key is completely withdrawn from the ignition-key cylinder each time it's removed. Turn the ignition to the ACC position and press any button on the remote one time. The hazard lights should flash twice, letting you know your mission is a success. If you were going to program more than one remote, you'd simply unlock and lock the doors once again with the driver's switch and press the one button, one time, on the second remote. The procedure is completed by turning the ignition off, unlocking with the driver's switch, and opening the driver's door.
Robert
Do you know if the conventional method will work with Infinit i35 2002? The dealer told me that this method no longer works and that a computer must be used. Is this accurate?
i am not sure i will ask around at work but i would just try it to see if it works if it does not then he might be telling truth.
Robert
Re: remote programming for Pathfinder
I own a 2002 Pathfinder SE that I bought used. There was never any mention of keyless ever on it. Is aw all the posts for programming fobs to the car but I can't tell if I have anything in the car to make it this simple? I looked in the fusebox where it said keyless and there wasn't anything...so is it possible for me to do this or do i have to buy a whole thing? Also how much would it cost to do it through a dealer?
I have a 2002 Nissan Maxima, 76k miles, I have tried to reprogram my remote with no luck. I followed all the steps & everything goes according to directions until I insert the key and turn to ON and push the lock button on the remote to program it. I get no hazard flash indication for the successful programming of the remote. I also replaced the battery.
Any suggestions???? Thanks for the help! |
marie, try it slower
.i just bought a remote and couldnt seem to get it to work. then i stopped rushing putting in and pulling out the key from the ignition. it then seemed to work, and i finally got the hazards i was finally looking for. close all doors, lock with power lock on drivers door insert and remove the key from ignition more and 6 times in 10 seconds ---dont rush that step---- hazards should flash, and push a button on the remote. wala.
2008 Mazda 6 ATX 2.3 Liters of Slowness For those 9 seconds it takes me to reach 60mph, will be the most fun ill have in this car. |
hi
i just buy a pathfinder 2008 u.s.a i am in canada is it the same prosess for program and someone have the parts # for the remote best regard's dan |
