Go Back   Automotive Forums Car Chat > Lamborghini > Diablo
Old 11-03-2002, 07:13 PM
allanf allanf is offline
Send a message via AIM to allanf
Twin Turbo Diablo SV
http://www.asahi-net.or.jp/~fp3k-htt/top1.htm
Old 11-03-2002, 09:02 PM
gemballa gemballa is offline
how many hp?
Lamborghini was made to be an ALL car killer!(specially for ferrari)!
Old 11-03-2002, 09:20 PM
It does not say, but it does say it will boost 1.4 which is huge boost, i think 18-20 pds, since 1.0 bar is 14.7pds. The vttt quoted something like 900hp at 15 pds. It must have extensive internal modifications, and i also know it uses a motec engine management system.
Old 11-04-2002, 10:03 AM
Menu dei Motori's Avatar
Menu dei Motori Menu dei Motori is offline
Click here
Send a message via ICQ to Menu dei Motori Send a message via AIM to Menu dei Motori Send a message via MSN to Menu dei Motori
i just know about that vttt:
TECHNICAL SPECIFICATIONS
Lamborghini Diablo VTTT
ENGINE
Type V12
Mid-longitudinal
Aluminum block and heads
chain driven DOHC per bank
Valves 4 per cylinder
Capacity 5,707cc
Bore/Stroke 87mm x 80mm
Compression 10:1
Turbos 2 Garret T4 turbos
Fuel System Weber-Marelli electronic port fuel injection
Max power 600bhp @ 6,800rpm
Max power 752bhp @ 6,800rpm
DRIVETRAIN
Transmission Four wheel drive
Gearbox 5-speed + reverse
Transfer-gear Ratio 1.59:1
Final-drive Ratio 2.41:1, limited slip
Clutch Dry single plate 10"
Gear Ratios
1st
2nd
3rd
4th
5th
Reverse 1:2.31 - 59 mph
1:1.52 - 89 mph
1:1.13 - 121 mph
1:0.89 - 154 mph
1:0.68 - 202 mph
1:2.12 - 65.5 mph
Differential Central - Viscous Coupling
Front Bevel Gear Type - Limited Slip 25% - Ratio 1:2.81
Rear Bevel Gear Type - Limited Slip 45% - Ratio 1:2.41
STRUCTURE
Chassis Steel-tubing space frame
Body Aluminum alloy, carbon fibre and fibreglass reinforced plastic
Wheels O.Z. Racing 3-piece, cast aluminum hub with forged aluminum rim
- front 8.5 x 17 inches
- rear 13 x 17 inches
Front Tires 245/40ZR-17 Pirelli P Zero
Rear Tires 335/35ZR-17 Pirelli P Zero
SUSPENSION
Front Independent unequal length control arms, coil springs, anti-roll bar.
Rear Independent unequal length control arms, 2 coil shock units, anti-roll bar.
BRAKES
Type Vacuum power assisted
Front 12.6 in. ventilated discs
Rear 12.2 in. ventilated discs
DIMENSIONS
Wheelbase 2674.4 mm / 104.3 in
Overall Length 4502.6 mm / 175.6 in
Overall Width 2059 mm / 80.3 in
Overall Height 1115.4 mm / 43.5 in
Front Track 1553.8 mm / 60.6 in
Rear Track 1656.4 mm / 64.6
Ground Clearance 143 mm 5.5 in
Weight 1701 kg / 3750 lb
Distribution
Front/Rear
40/60
Fuel Tank 26.4 U.S. Gallons
PERFORMANCE
Top speed - 600bhp 222mph
Top speed - 752bhp 255mph
and the svtt
1998 Lamborghini Diablo SVTT Specifications
General Information
Price: $259,000
Miles Per Gallon: --/-- mpg
Curb Weight: ---- lbs
Layout: Mid-Engine/RWD
Transmission: 5-Speed Manual
Engine
Type: Twin-Turbo V12
Displacement: 5707 cc
Horsepower: 750 bhp @ ---- rpm
Torque: --- lb-ft @ ---- rpm
Redline: ---- rpm
Performance
0-60 mph: 2.9 sec
0-100 mph: 6.4 sec
Quarter Mile: est 10.3 sec @ 140 mph
Skidpad: .98g
Top Speed: 200+ mph
Braking, 60-0 mph: --- ft
Slalom Speed: --.- mph
these are dates from two different sites... and i donīt know if they are correct
Old 11-14-2002, 10:41 AM
jsb88's Avatar
jsb88 jsb88 is offline
That is one hell of a lot of information! thank you!
Old 11-16-2002, 06:12 AM
Click here
no problem
wasnīt too easy to find these specifications of this rare/unique car
Old 11-16-2002, 07:35 AM
jsb88's Avatar
It is very hard to find real specificatioons in the first place! Maybe we should make a website, telling the real specs of cars, and how fast they really go, with some background information too!
Old 11-16-2002, 07:42 AM
Click here
and we test them
Old 11-16-2002, 10:28 AM
jsb88's Avatar
If you properly advertise yourself, then you will get free car reviews, but you basically can only say good things about it unless you are very, very influential with a reputation to uphold.
Old 11-16-2002, 12:55 PM
Click here
the husband of my godmother (what a word!!!) has a job like that
he even tested the enzo ferrari as one one the first!
all week he gets another car! thats a cool job
his name is Georg Kacher .. he is well known in germany
Old 11-17-2002, 03:20 AM
jsb88's Avatar
That is the sort of job I would want!
Old 11-17-2002, 05:04 AM
Click here
maybe iīm gonna make a kind of apprenticeship with him
but my english must get better ..
so i probably go to england or southafrica for some time
Old 09-29-2003, 02:48 PM
Stratoraptor's Avatar
Stratoraptor Stratoraptor is offline
Send a message via AIM to Stratoraptor
does any one know how many SVTT and VTTT Diablos were built?
Old 09-29-2003, 04:00 PM
jsb88's Avatar
I think I posted a list of Diablo numbers built in which years and what models somewhere around here. Have a look around.
Old 09-29-2003, 05:09 PM
hiphophomer's Avatar
hiphophomer hiphophomer is offline
Banned
is it hard to find a svtt for sale?
twin turbo WS6 vs. twin turbo supra doodad Camaro Discussions 17 03-14-2006 08:21 PM
300ZX Twin Turbo vs. Supra Twin Turbo Automobile Maniac General 31 08-10-2005 03:05 PM
300ZX Twin Turbo vs. Supra Twin Turbo Automobile Maniac 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 49 10-03-2004 10:28 AM
question about the 1278 hp Diablo twin turbo Diablo SE30 Diablo 29 09-13-2004 04:29 AM
Twin turbo Diablo blueboost Car Modeling 8 11-04-2003 05:55 AM
