Go Back   Automotive Forums Car Chat > Chrysler > LHS
Old 11-01-2002, 07:02 PM
BobH BobH is offline
Thumbs up LHS Headlights
LHS Headlights can be upgraded with the new Xenon 9007 bulb available
on the web from http://liteemporium.safeshopper.com/index.htm?584
My light output is considerably increased and it is white light.
If you own an 1995-1999 LHS, you need these bulbs. $25.00 for the pair.
Old 10-05-2004, 04:17 PM
DARKANGEL01 DARKANGEL01 is offline
Re: LHS Headlights
what about a 01
Old 02-26-2005, 11:43 PM
Gold-LHS Gold-LHS is offline
Re: Re: LHS Headlights
Originally Posted by DARKANGEL01
what about a 01
I have an 00 with projection headlights and I think that the 01 is the same. I am using Sylvania SilverStar Xeon bulbs. 9006 for the low and 9005 for the high beams. The fog lights are a 9040 bulb that is not available anywhere in xeon. I modified the fog light housing to take a 9006 low beam bulb. Just bore the housing to .875 diameter and remove the center rib on the cars connector. A 9005 will fit in the stock housing but I wouldn't recomend it. Going from a 40 watt to a 65 watt bulb is a big heat difference. The housing will probably melt.
headlights davidrobert2 Intrepid 1 11-20-2009 02:02 PM
93 Aerostar, no Headlights billa63 Aerostar 2 03-08-2009 06:10 PM
Locked front brakes, brake light out, headlights gone kruqnut Problem Diagnosis 19 02-26-2009 08:49 AM
1994 Lhs Headlights Wont Work snowbrder LHS 0 02-05-2007 10:52 PM
