Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 10-31-2002, 09:14 PM
hondatool hondatool is offline
Question wastegates
what would swapping wastegates do for my car...i dont know much about wastegates?
Old 11-02-2002, 11:15 AM
BILLIE JEAN BILLIE JEAN is offline
waistegate
waistegates regulate the boost in a way. you can adjust how much boost you want to run with it. some are set for different amounts. the spring inside is set for a certain amount of boost. you can't boost more then the waist gate spring will let you unless you have a boost controller. if you have a waistgate for 6 pounds you shouldn't turn the boost up to 15 pounds cause you can mess up the spring. get a waiste gate that is set as close as possible to the amount of boost you want to run if you don;t want your waistegate to crap out.:smoker2:
waistegate
stage 2 wastegate or kinetic wastegate blksrt4_2005 SRT4 14 03-26-2011 01:04 AM
Internal Wastegate to External wastegate fiberglasscivic N2O | Turbo | Superchargers 13 06-22-2006 12:34 AM
T3 w int. wastegate on manifold w ext. wastegate outlet? wickedboost N2O | Turbo | Superchargers 5 01-09-2005 02:30 PM
Can u turn a T3 non wastegate to internal wastegate Lac-O-Power '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 03-10-2004 02:58 PM
Help with tuning and Tial wastegate zapf Engineering/ Technical 1 11-15-2001 11:33 AM
