Old 10-27-2002, 12:52 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Moisture in headlights.
Anyone know a good, clean way to fix this problem?
Old 10-27-2002, 12:56 AM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
I would say drill holes in the bottom of the headlight for the water to go out of, but you probably dont want to hear that ghetto shit.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 10-27-2002, 01:02 AM
kris's Avatar
lol
Old 10-27-2002, 01:16 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
Leave your headlights on the dry out the lense, then try sealing the edges around it.We've had some luck at work with that...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 10-27-2002, 01:59 AM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
I took the lens apart cleaned them really good with windex and a cotton cloth so not to scatch the reflector and put them back together with black silicon no leeks so far. Its benn 4 months now
Old 10-27-2002, 01:19 AM
GTA's Avatar
GTA GTA is offline
Whee..
My right tail light is like that. I replaced the gasket and it still filled up with water....so i drilled holes in it
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 10-28-2002, 12:21 AM
BullShifter's Avatar
buy a new light assembly
Old 10-28-2002, 12:25 AM
kris's Avatar
I did, and they still leak. I don't want to spend god knows how much for brand new lights.
Im thinking I will try and seal them up somehow.
Or maybe projectors...
Old 10-28-2002, 08:27 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Originally posted by kris
...Or maybe projectors...
There ya go dude...that's the ticket.. I have a rock that hit my left headlight and for a while I used a dab of silicone on the lens in the hole to keep it dry, and that worked for a long time..That is my excuse for projectors if I can ever save money for something I don't "need"
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 10-28-2002, 09:10 AM
BMciv BMciv is offline
I had the same problem. I took out both bulbs, used a hair-dryer to blow in HOT air through one of the bulb holes (low beam, also took off the air box). The condensation will disappear in a few minutes due to evaporation, you'll also notice that the glass will warm up more than usual, and I think this re-sealed the lamps because of the heat.
Old 10-29-2002, 11:08 AM
kaytec4door kaytec4door is offline
well here is one way to do it but its not the easiest but i havent had it fail yet, first you take the light and either boil it in water to get the silicone to break up or you take a blow drier to it. once you get it apart you can clean the piss out of it the silicone the edges and put it back together and thin put silicone around the seal on the outside and wipe away all the acces silicone. it works nice but its better than drilling holes in your lights,
:smoker2:kaytec4door:smoker2:
mods done: AEM cold air intake,
ractive racing cat,
ractive axel back exhaust,
NGK plugs,
nuespeed cross-drilled rotors,
EBC the green stuff pads,
projecter headlights,
clear corners,
carbon fiber tails,
Z3 fenders,
adjustable coilovers,
Konig flatline rims with dunlop fm901 (17*7),
full complete sound system with two 10'' subs,
kenwood 600w amp,
punch cap,
pionner speakers all the way around,
full custom interior paint job,
reverse indiglo guages,
aluminum gauge bezel,
d16a6 head swap polished,
4-2-1 ceramic coated header,
:finger4: proud member of team kay tec:finger4:
Old 10-29-2002, 03:30 PM
Brad McCoy Brad McCoy is offline
I had the same problem with my tail lights.
I did not take them apart, just dried them real good and
put a thin bead of clear silicone on them.
Had a slight leak in one and had to re-silicone it.
No leaks for about three months.
Old 02-15-2004, 02:40 PM
fiercecivic's Avatar
fiercecivic fiercecivic is offline
Send a message via AIM to fiercecivic Send a message via MSN to fiercecivic
Re: Moisture in headlights.
anyone know how to take the front lense off? how many clips are there?
Old 02-16-2004, 01:17 AM
Re: Re: Moisture in headlights.
WOW, old enough thread?
You have to remove the front bumper to remove headlight assy. Well you really don't have to, but it makes life so much easier. Bumper removal takes a whole 5 min.
Old 02-16-2004, 02:11 AM
90civicracer's Avatar
90civicracer 90civicracer is offline
Send a message via AIM to 90civicracer
5 minutes to do it the right way...less than a minute if you just yank, lol.
***90 Civic EX 4 Door***
Ace$nyper: yea it did woo woo 4500 posts i should be ashamed *kills self*
90civicracer: haha you killed yourself you got
Ace$nyper: OMFG LOL that might be the funniest thing you EVER posted
bwhahahaha
headlights davidrobert2 Intrepid 1 11-20-2009 02:02 PM
Change 2006 Allure Headlight kale39 LaCrosse/Allure 1 04-28-2009 06:05 AM
01' Headlights frehleycomet Sebring | Sebring Coupe | Convertible 2 04-14-2009 08:47 PM
93 Aerostar, no Headlights billa63 Aerostar 2 03-08-2009 06:10 PM
Locked front brakes, brake light out, headlights gone kruqnut Problem Diagnosis 19 02-26-2009 08:49 AM
