Old 10-19-2002, 10:42 PM
tkdfyter tkdfyter is offline
B16a V.s. B16b
What makes the B16B motor make more power than the B16A motor?
They're both the same displacement. I know that the B16B has higher compression... If that's it, then wouldn't it be cost efficient to buy B16B pistons for a B16A to sorda make the "poormans Civic Type R"?
I was just wondering, got thinking today about why it makes so much more horsepower...
later,
Caleb
Old 10-21-2002, 12:14 AM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
The B16B motor is hand assembled. The head has mild port and polish job....and flows by far better than the all ready good flowing B16A head. The camshafts are the best Honda has to offer. The intake cam actually has 3 degrees more lift/duration than the Integra Type Rs...and the exhaust cam is identical to the ITRs. The pistons are high compression and it has a slightly larger bore i believe...the rods and crank are also stronger to allow it to rev to 8400rpm on a daily basis w/ reliability. The entire valve train is better and made to withstand high Rs. I dont know all of the specifics...but these are SOME of the reasons for the 25-30crank hp difference between the JDM first gen B16A..and the USDM B16A....and the CTR B16B.
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
Old 10-21-2002, 09:03 AM
What is the difference between the JDM B16A and the USDM B16A?
Hp/torque? Reliability? Revving? And why is there a difference?
Also for first gen JDM B16A can you rev it to 8k daily w/ reliability?
later,
Caleb
Old 10-22-2002, 09:04 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
I am not a B series guy but I will answer to the best of my knowledge. There is not really a diffrence between the Sir1 (JDM) b16 and the (USDM) b16 exept on the JDM b16 there is a more aggressive fuel curve programed into the ECU.
Now on the Sir2 (JDM) b16 there is a .2 higher compression ratio and also a more aggressive ECU program which enabled the B16 to have 10 more horses over the (USDM) Sir2 B16.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 10-25-2002, 02:09 PM
YOUNGSTER YOUNGSTER is offline
Send a message via AIM to YOUNGSTER Send a message via MSN to YOUNGSTER Send a message via Yahoo to YOUNGSTER
yeah your about right the bad thing if you get the jdm version you need to detune the ecu because they are set to run 93 octane gas you might have octane that high where you live but in cali we get 91 93 is hard to find
B16B vs. B16A? CRX586 '88 - '91 Civic | CRX | Wagon | Shuttlee 15 05-13-2010 02:48 PM
B16A vs. JDM B16B northtexasskater Let's get Technical! 5 04-06-2004 02:25 AM
B16A parts compatible with a B16B engine? Ricochet Engineering/ Technical 16 06-28-2003 11:35 PM
B16a to B16B? B18B to B18C5? FastTeen Engineering/ Technical 12 05-05-2003 12:49 PM
