Old 04-28-2003, 02:50 PM
FastTeen FastTeen is offline
B16a to B16B? B18B to B18C5?
can a b16a be converted to a b16b? and can a b18b be concerted to a b18c5?
95 Ford F250 ext cab long bed Powerstoke Diesel, stock. 92 Ford Mustang LX 5.0: Trick Flow R series intake manifold, Cold Air Intake, Throttle Body, Larger Egr Plate, Flowmasters, 3.73 Gears, Off road H-pipe.
Old 04-28-2003, 08:20 PM
Kill4A911's Avatar
Kill4A911 Kill4A911 is offline
Send a message via AIM to Kill4A911
yea you could swap heads, you might run into problems later on with the B18b because its not meant to rev that high, the internals are not as strong and i dont think it has oil squirters. but you could still build a nice LS/Vtec, the LS has a lil' more displacment (37cc). for the trouble i would go CRVtec with a B20
Civic:selling the D16Z6 getting ready for a B16 turbo
240Z:was thinking about a VG30DETT but am now looking at a V8
Old 04-29-2003, 12:43 AM
94tegRS's Avatar
94tegRS 94tegRS is offline
isnt the B16a and b the same besides the head?
the B18b and c5 though are completely different. no oil squirters, worse(not much though) R/S ratio, and the heads are different(no vtec, etc.)
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 04-29-2003, 12:48 AM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
Don't forget the high comp pistons. The dome on those damn things are CRAZY!!!
Old 04-29-2003, 12:54 AM
B16EJ1's Avatar
Check out the dome.
Old 04-29-2003, 06:33 PM
liquid8 liquid8 is offline
Send a message via AIM to liquid8
the c5 does have vtec. it's the integra type r motor
"life's a bitch but god forbid the bitch divorce me" - nas
Old 04-29-2003, 07:24 PM
Kill4A911's Avatar
damn that is a big dome, yea since the b16a/b are both vtec i think their pretty much the same
Old 04-29-2003, 11:10 PM
94tegRS's Avatar
If this was to me, I know, I said the B18b and C5 are comletely different, the B18b has no oil squirters, worse R/S ratio, no vtec, etc) which means the C5 has oil squirters, better R/S ratio and Vtec. but I see how you got confused, I wasnt clear with my statement.
current
history:
Old 05-01-2003, 03:25 PM
CRXSiR1's Avatar
CRXSiR1 CRXSiR1 is offline
B16a/B16b
Isn't the B16b a destroked B18 Block? B16a block is different than B16b.
Dan The Fisherman
Old 05-01-2003, 03:46 PM
Kill4A911's Avatar
yea the block is taller and it has stronger internals, better cams etc. but all the B series engines are very closely related.
Old 05-01-2003, 06:38 PM
edman24 edman24 is offline
Send a message via AIM to edman24
ALL the b series engines share the same size block. what differs is the crankshaft, bore size, rod ratio, piston height, and in some cases mounting points. but they are all based off the same size chunk of metal.
I feel bad for those who pay twice as much as i did for my car and still lose to me. The sorrow in their face is enough to bring me to tears.
Old 05-01-2003, 08:27 PM
Kill4A911's Avatar
um yea except for the fact that a B16B block is 270mm same as a B18C, and a B16A is 263mm . so their not exactly the same block
Old 05-05-2003, 12:49 PM
Mean_B16's Avatar
Mean_B16 Mean_B16 is offline
Re: B16a to B16B? B18B to B18C5?
Yes
